OEM heated grips issue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-01-2019, 08:59 AM Thread Starter
Hi,
Hi, I have a 2010 v Strom 650 with 25k on the clock. I'm looking for a bit of advice with the OEM heated grips, they will come on and heat but once you are out on the road and the revs go up, the grips go off, I think there might be some sort of voltage overload. Has anyone had this experience and what did you do to fix it.
Would it be possible to swap out the control with an Oxford control and let the grips and wiring in place.
Roosk is offline
post #2 of 6 Old 07-01-2019, 11:05 AM
Hard miles's Avatar
Are you certain that the increase in cold inflicted on the metal handlebar (at speed) is not the one sucking away the heat from the heated grips? That what happens in my case especially when riding in below 5C ambient temperatures. The grips are still working but I don't feel it working.
Hard miles is offline
post #3 of 6 Old 07-01-2019, 11:31 AM
Gert's Avatar
Perhaps this hand guard mod may help keep the wind / cold off the grips, so that the heated grips can get a chance to do it's job, Alain27 - extensions supérieures de pares mains
Gert is offline
post #4 of 6 Old 07-01-2019, 12:47 PM
Bigfeet's Avatar
Originally Posted by Roosk View Post
Hi,
I have the OEM grips and for me they have worked very in low temps. If anything, they are too hot with thinner gloves.
The problem that you’re describing is actually a feature according to the Suzuki heater set installation and user instruction book:
Note: The grip heater has a built-in automatic switch to avoid unnecessary battery power consumption. The automatic switch turns off (the) grip heater when engine speed becomes lower at engine idling speed. Hen engine speed increases, the automatic switch turns on (the) grip heater.
Pushing the switch will not turn on the grip heater when the engine speed is low. Increase the engine speed and push the switch again to turn on the grip heater.
HTH
M.
Bigfeet is offline
post #5 of 6 Old 07-01-2019, 05:41 PM Thread Starter
Thanks for replying, temperatures are around 17 degrees Celsius at the moment so there is no heat being drawn to the bars. I understand the grips switch off at idle, it definitely doesn't come on at normal driving speeds, l can press the switch and all lights come on, at idle it flashes.
I think it's definitely some voltage overload, that's why I'm thinking of just changing the regulator to Oxford
Roosk is offline
post #6 of 6 Old 07-01-2019, 06:29 PM Thread Starter
Just to clarify, when I'm filtering through traffic at low speeds they work and get hot
Roosk is offline
