Starting/clutch issue, HELP - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #1 of 42 Old 06-24-2019, 01:09 PM Thread Starter
Joshua24:15's Avatar
Not starting. 06 vstrom
So i ended up dropping the bike on the left side. Ended up breaking the round top of the clutch lever, after picking it up I tried to start it to no avail. I hear the fuel pump turn on so I don't believe it's the kickstand switch, I unplugged and plugged back in the clutch switch and still nothing, doesn't look bent unless something got broken inside the switch. I noticed the clutch lever was a bit tweeked. I tried loosening and then tightening the lever and even the cable underneath but still to no avail. When I put the bike into first and then pull in the clutch it feels like the clutch is (slightly) engaged because the wheels move alittle but but when I put it back into neutral it moves easily and freely. Any advice would be greatly appreciated and let me know if this has happened to anyone else. Thank you!! -Joshua. 2006 vstrom DL650
File Type: jpg IMG_20190622_170641725_1561396159382.jpg (245.7 KB, 10 views)
Joshua24:15 is offline
post #2 of 42 Old 06-24-2019, 01:55 PM
Stalky Tracker's Avatar
I'd disconnect the clutch switch and try jumpering it. That will eliminate the switch as a possible problem.
And welcome to the forum, Joshua.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #3 of 42 Old 06-24-2019, 02:56 PM
Try starting the bike in neutral, if no luck then take a look under the seat at the safety switch that kills the engine when the bike falls over. The switch might not be sitting up in the vertical position therefore the bike still thinks its on its side.
If it does start in neutral, I would take a closer look at the clutch lockout switch then the side stand lockout switch.
gdrew is offline
post #4 of 42 Old 06-24-2019, 03:21 PM Thread Starter
File Type: jpg IMG_20190622_170641725_1561404054633.jpg (245.7 KB, 10 views)
post #5 of 42 Old 06-24-2019, 03:47 PM
Rolex's Avatar
It is not unusual to have a little clutch drag especially when the oil is cold, the plates don't spin freely.
Just tweaking your leaver like that should make no difference to your adjustments so it could have always been a problem ??
Your clutch has 2 adjustment points, one at your leaver and one down near your front sprocket.
They are both very important, you need some free play in the cable and at the push rod but not too much.
Do a search on this site and you will find the adjustment procedures for your bike but as I said just snapping the end off your leaver should make no difference so it may not require adjustment.
Are you having trouble starting the bike because the clutch switch is not working ???
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is online now
post #6 of 42 Old 06-24-2019, 03:57 PM
jokermtb's Avatar
if you remove the clutch safety switch and run a wire from contact to contact, you can bypass this feature - eliminating one variable. Have you tried this?
Also, and I know it's kinda a dumb one, but the engine on/off switch on the right grip pod - is it in the 'off' position?
jokermtb is offline
post #7 of 42 Old 06-24-2019, 05:47 PM Thread Starter
How would I disconnect the switch and put ( contact to contact)? By chance would you a picture a link to how to do this? Thanks in advance 🙂 I plan on logging alot of miles and posting my travels.
post #8 of 42 Old 06-24-2019, 06:31 PM Thread Starter
Thanks for the advice, I'll try to remember to post back on this forum when I check the bike next. 😄
post #9 of 42 Old 06-24-2019, 07:12 PM
Brockie's Avatar
Am I correct in that you have failed to restart your bike after the drop?
It looks to me as though your kill switch has been activated. Do you have CHEK up?
Otherwise ensure that the clutch lever does actually press the clutch switch.
Gert likes this.
Brockie is offline
post #10 of 42 Old 06-24-2019, 11:53 PM
What is this "CHEK"???
RLBranson is offline
