Starting/clutch issue, HELP - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #31 of 42 Old 06-26-2019, 06:16 AM
Rolex's Avatar
If need be you can drill the hole further back where the leaver is straight then use your heel for up shifts.
I carry a product called form card, heat up in hot water then mould into the desired shape, can even replace a missing nut....
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #32 of 42 Old 06-26-2019, 08:26 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Originally Posted by gdrew View Post
Try starting the bike in neutral, if no luck then take a look under the seat at the safety switch that kills the engine when the bike falls over. The switch might not be sitting up in the vertical position therefore the bike still thinks its on its side.
If it does start in neutral, I would take a closer look at the clutch lockout switch then the side stand lockout switch.
The what? We have one of those? What does it look like?
richlandrick is offline
post #33 of 42 Old 06-26-2019, 08:50 AM Thread Starter
Joshua24:15's Avatar
This is what the tip over sensor looks like
Joshua24:15 is offline
post #34 of 42 Old 06-26-2019, 09:24 AM Thread Starter
it's the knob itself that it bent.
post #35 of 42 Old 06-26-2019, 02:17 PM
Rolex's Avatar
Yes I understand that.
It makes no difference you can still use the bolt and 2 nuts you just make a shorter leaver then use your heal to operate the up shifts.
2014 V2, Snoopy
Rolex is offline
post #36 of 42 Old 06-26-2019, 04:36 PM
Stalky Tracker's Avatar
Do you have a link to those levers that you got from eBay?, And as well for the switch, the wires were in place but every time I tried connecting the plug to the switch it would not work, then I took a piece of metal and out it on the two metal pieces on the plug switch and it fired up every time.
Here's their eBay link: https://www.ebay.com/str/The2Wheels
They also have their own website now too: https://www.the2wheels.com/
I think this is the updated version of the ones I purchased: https://www.the2wheels.com/products/...set-for-suzuki
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #37 of 42 Old 06-27-2019, 09:17 AM Thread Starter
Thanks guys, appreciate all the help and advice, I'm going to change the sprockets and chain, airfilter and hopefully coolant since I will have the tank off already.
post #38 of 42 Old 07-02-2019, 12:07 PM Thread Starter
Not sure if anyone else is subscribed still to this forum, but I was wondering what kind of cheap mods have you guys done to your bikes?
post #39 of 42 Old 07-02-2019, 08:47 PM
Dragon Rider's Avatar
In case you don't know, there is a hidden, powered, and fused connector in the fairing. It is there to power the oem grip heaters.
Eastern beaver, I think, makes a connector that fits there. (it has been so long I forget where it came from) But once you get the connector in there, you've got power for anything you want to add to the front. I've installed a cigaret lighter, usb power, and two pair of cheapo ebay led fog lights to the front.
If you are looking for super cheap, put the lights down by the front wheel by just adding them (glue, gorilla tape, zip ties, etc) to the round reflector already there, no mounting hardware needed.
I wanted a taller seat, so I found a dl1000 rider who wanted a shorter seat, so we swapped. Free seat mod for each of us.
And if you have crash bars, you can find some cheap ($10 each or so) bags to add to them. Mine are simply zip tied to the crash bars.
09 DL650A
Dragon Rider is offline
post #40 of 42 Old 07-04-2019, 09:33 PM Thread Starter
the 650is tricked out nice! I plan on once I get more funds I definitely want to add more mods to mine. The plastics are unfortunately not in the best shape and the previous owner painted them almost a matte color on the fairings. I keep an eye out on eBay for used ones and for other mods as well. Thanks for the advice.
