Starting/clutch issue, HELP - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #21 of 42 Old 06-25-2019, 07:04 PM
Brockie's Avatar
Originally Posted by Joshua24:15 View Post
Any advice on some clutch levers that would reach the switch? I saw these ones on Amazon and are fairly inexpensive for both levers. Let me know if you think these would do the job. https://www.amazon.com/Motorcycle-Ad...+DL650+V-Strom
I like shorty levers as well as they are less likely to be damaged in a fall, and I find the full length lever unnecessary. These are adjustable as well.
They should work. Just be sure before you fit them that the protrusions that operate the clutch switch etc. are actually there.
Brockie is offline
post #22 of 42 Old 06-25-2019, 07:46 PM
Stalky Tracker's Avatar
Looks like they should. I picked up a set of cheap knock-offs from The2Wheels on eBay about 7 years ago. Very similar to those in your link but gold and the long version. They have worked fine.
I had the adjuster on the clutch lever up to 6, and then my switch started to fail periodically until I replaced it. Now I am back to 4.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #23 of 42 Old 06-25-2019, 08:24 PM
Rolex's Avatar
The 2 wires I asked you to join at the clutch switch were they pushed onto the 2 clutch switch terminals properly before you removed them to do the test ??
When that bike is dropped on the left side often when picking the bike back up again those wires can get pulled from the switch and that will stop the bike from starting.
V-Tom likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #24 of 42 Old 06-25-2019, 09:31 PM Thread Starter
Joshua24:15's Avatar
Do you have a link to those levers that you got from eBay?, And as well for the switch, the wires were in place but every time I tried connecting the plug to the switch it would not work, then I took a piece of metal and out it on the two metal pieces on the plug switch and it fired up every time.
Joshua24:15 is online now
post #25 of 42 Old 06-25-2019, 09:44 PM
Brockie's Avatar
You should replace that switch. Any repair may let you down at an inconvenient time.
SWITCH ASSY, CLUTCH PN37560-31F00 $12.90
https://www.suzukipartshouse.com/oem...witch-model-k4
Brockie is offline
post #26 of 42 Old 06-25-2019, 09:54 PM Thread Starter
I bought one off of eBay today, should get here Friday.
post #27 of 42 Old 06-25-2019, 09:58 PM Thread Starter
I also broke the knob off the shifter , get your laughs in today haha , gotta do what you gotta do. ( Part should be here tommorow) 😅 😂
File Type: jpg IMG_20190623_173221343_1561514216097.jpg (306.4 KB, 6 views)
V-Tom likes this.
post #28 of 42 Old 06-26-2019, 02:14 AM
Rolex's Avatar
You can drill a hole in the gear leaver and put in a bolt with 2 nuts, one either side of the leaver.
It will get you going again.
2014 V2, Snoopy
Rolex is offline
post #29 of 42 Old 06-26-2019, 03:13 AM
Gert's Avatar
Similar to the advice by Rolex. They say a pix paints a thousand words. An example from a French site, skyfox38 - Réparation rapide du sélecteur de vitesses. Use the translation tool, if required. Let us know how you fair.
Gert is offline
post #30 of 42 Old 06-26-2019, 05:20 AM Thread Starter
That is pretty neat and smart idea, unfortunately with my knob it was bent upwards before breaking off, so it sits in a upward position, I ended up buying a cheap folding shifter from ebay, I've seen some others use them as well. Btw how so you guys feel about frame sliders? I don't have the money for crash bars atm and figures something is better then nothing. I'm tired of breaking stuff when falling lol.
