Countershaft Spline damage - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By RLBranson
post #1 of 5 Old 05-19-2019, 07:10 PM Thread Starter
Sadly the splines on my output shaft have been slowly declining. While I have the capability of dropping the motor and splitting the cases. I really don't want to. Has anyone successfully had the splines built up with weld and then filed down so the sprocket fit, while in the bike? The last sprocket and the one I put on yesterday I used a bearing sleeve retainer compound between the splines and sprocket, and then red loctite on the sprocket nut.
The other idea I have been considering is welding the nut to the sprocket.
The bike has 110,000+ miles and has led a hard life. I have a nicer/newer one sitting next to it but I really prefer riding this one as it tells a story and has a lot of sentimental value.
Thoughts?
pjm204 is offline
post #2 of 5 Old 05-19-2019, 09:11 PM
Condolences, I had splines go out on a clutch on a BMW but that was an easier repair.
Good luck.
notacop is online now
post #3 of 5 Old 05-19-2019, 11:25 PM
of course if you weld it on, even small welds. the heat will destroy the shaft seal. then you won't be able to replace the seal because the sprocket is welded on. I think I would try building up the splines with weld. a small amount of weld then cool the shaft with a wet rag then compressed air to cool and dry the area. slowly build up the shaft, then use a 4 inch grinder to reduce the diameter of the shaft while the engine is running in gear to grind it down evenly. then use a dremel and cut off wheel to recut the splines.
But then I am a retired welder and if your only skill is as a welder, then all problems look like welding problems.
Motor7 and Hatchi like this.
RLBranson is online now
post #4 of 5 Old 05-20-2019, 11:27 AM Thread Starter
It's funny, I've been worrying about melting the seal when I've replaced it in the past! I worked for a couple years at a welding shop (operating a lathe), I think the owner would do the welding for me. I may just have him do half of the splines and focus on keeping the sprocket nut tight in the future. Thanks!
pjm204 is offline
post #5 of 5 Old 05-20-2019, 11:28 AM Thread Starter
Good luck.
Yea I wish this were easier! Thanks
pjm204 is offline
Seeking Accident Damage Analysis/Opinions sawdura DL650A - 2012-2016 25 12-27-2014 08:29 PM
GIVI Crashbars did the job! No Damage at all. FoxOrange DL650A - 2012-2016 13 03-25-2014 09:09 PM
Post Crash Damage Checklist hansong General V-Strom Discussion 12 08-29-2011 10:07 PM
Post Crash Damage Questions msgvb General V-Strom Discussion 34 07-09-2010 04:30 PM
