New to me 07 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 21 Old 04-28-2019, 04:30 AM Thread Starter
jelliff's Avatar
New to me 07
2007 wee strom. I Just picked this up the other day. What I know is that the abs has been bypassed by the dealer. Past that....64k on the clock
What should I be looking at for maintenance aside from getting the clearances checked?
Happy trails rack and panniers, progressive suspension, superbrace, givi tail trunk, cee Bailey windscreen, heated grips, throttlemeister, pyramid fender extender, sw motech engine guards, and plenty more like The touratech kickstand plate adapter
I got what I think is a very good deal, at a dealership, so I am cautiously happy at the moment
Who knows. Maybe the previous owner is still on here looking at this thread. If u r please fill me in.
File Type: jpg 616FB99A-A986-484D-9DA3-08AD1BF52DF3_1556436174115.jpg (637.6 KB, 16 views)
File Type: jpg 97396905-3450-4CF9-A70C-6C8156A388F1_1556436260424.jpg (595.2 KB, 14 views)
jelliff is offline
post #2 of 21 Old 04-28-2019, 04:39 AM
Gert's Avatar
The information that you have provided, does not explain enough as to why you may think that the ABS may have been bypassed? Any FI code or warning light displayed, either stationary or while riding? Have you checked whether the ABS fuse has been pulled?
Gert is online now
post #3 of 21 Old 04-28-2019, 07:31 AM Thread Starter
jelliff's Avatar
I wasn’t necessarily asking for abs information. That was more just stating how it came to me when I purchased it. I will look further into that part later.
I am more along the lines of asking about general items I should be looking at and addressing for the age and mileage of the bike such as the valve clearances and wear components
Thank you
jelliff is offline
post #4 of 21 Old 04-28-2019, 08:16 AM
Big Boy's Avatar
Congratulations jelliff on the 'new to you' Wee!!!
W. C. Fields
Big Boy is offline
post #5 of 21 Old 04-28-2019, 08:22 AM
om28's Avatar
I assume there's no maintenance records from the previous owner. The typical thing to do would be to replace all fluids if the dealer hasn't done so. Check radiator hoses for drying and cracking, take a peak at the brake pads and air filter, look for kinks in the chain. Put a meter on the battery, it should hold a charge between 12.5 - 12.8 volts, it could be the original battery, my '09 is still running on the original, I want to replace it before it dies. Check valves.
You may want to get an Eastern Beaver headlight relay. A typical problem is the headlights stop working because of too much voltage going through the starter button. Easy install, it won't fix the problem, it prevents it from happening, so don't wait. Stators have been known to fail, some very early and some never. My '09 has 75K miles and hasn't given me any problems.
2009 Wee Strom ABS (current)
1987 Harley FXR Low Rider Sport (current - with 206K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, 1'' up & back bar risers, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
post #6 of 21 Old 04-28-2019, 05:17 PM Thread Starter
jelliff's Avatar
Excellent information there. Thank you
Eastern beaver headlight. Copy that
The po did mark generic maintenance on a piece of tape and then affixed to the underside of the pannier lids. So if I am believing that information I have a fresh oil change and new tires and more
Valve clearances were not marked so I know they’ll get done. Eastern beaver headlight now, front and rear wheel bearings.
I’ll have a list made up and start cracking on it
Thanks for the help so far folks
jelliff is offline
post #7 of 21 Old 04-28-2019, 05:45 PM Thread Starter
jelliff's Avatar
Okay. So I will do more looking then tomorrow to see what is there and isn’t as far as upgrades. I don’t believe the po was shy about modding and adding farkles when he owned it. That’s partly the reason I bought it. Who knows. Maybe the eastern beaver relay kit is already done??? I’ll know tomorrow
I will add a volt meter with a usb, as the current charging port that is on it I have no idea what it charges. I’ll add a pic and hopefully you guys can tell me. Maybe a heated gear port or the like. I have no idea
File Type: png 1D2165EE-2631-407B-A552-8AB71888ABA1_1556483893730.png (2.00 MB, 11 views)
jelliff is offline
post #8 of 21 Old 04-28-2019, 07:19 PM
Looks like maybe an upgraded seat too! I previously had an '06 Wee, and your seat looks much better than the stocker I had. Possibly a Corbin? In any event, you have a well farkled bike with many miles left on it. It is a nice looking rig; you will get many miles of service out of it.
talonstrom72 likes this.
Houstrom46* is offline
post #9 of 21 Old 04-30-2019, 01:08 PM
Definitely an upgraded seat. I have an 07 Wee for 4 years now. THe longest I"ve ever ridden the same bike. The only common potential issue I've encountered is the idle solenoid, which typically craps out around 20-30k miles. You're well beyond that so it should be fine, or already replaced. No big deal. The stator becomes an issue starting on 08 models as the output is higher. The 07 is usually ok. No other problems. The engine is noisy, as they all are. The Wee tends to use a little oil if consistently ridden at high speed (over 70mph). This is normal. The above advice is excellent but this is a bike capable of exceeding 100,000 mile with regular maintenance.
Wee Willy Winky is offline
post #10 of 21 Old 04-30-2019, 01:10 PM Thread Starter
jelliff's Avatar
Why did the po put this on the bike and what would be the reason for it??
File Type: jpg 065671B2-1920-4981-9609-0B65615F8F33_1556640548664.jpg (308.6 KB, 9 views)
jelliff is offline
