blinking LED stoplights? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By richlandrick
post #1 of 8 Old 04-25-2019, 05:11 PM Thread Starter
Advertised on ebay and amazon.com. supposed to blink several times then stay on and bright when braking. sounded good. I bought 2 from amazon and they blink several times then go off. sent them back as defective. neighbor says that because they draw less current, the computer thinks there is a problem in the brake light circuit and turns power off to the brake lights.
Has anyone else tried these blinking led brake lights? if so how did they work for you?
RLBranson is offline
post #2 of 8 Old 04-25-2019, 05:32 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
richlandrick is offline
post #3 of 8 Old 04-25-2019, 08:28 PM
OCADVR's Avatar
Originally Posted by richlandrick View Post
+1 on these.
Jack
SoCal 92691
"I feel more like I do now than I did a while ago."
OCADVR is offline
post #4 of 8 Old 04-26-2019, 12:25 PM Thread Starter
I don't know if those modulators will work with led bulbs and I really want led bulbs. LED bulbs don't burn out and that means a great deal to me. I had a burned out tail light and didn't know about it until a kind policeman informed me. I was lucky that time and just got a warning. I see the light put out by the headlight but not the tail light and brake lights. everybody should do a pre flight inspection of their bike before a ride. but modern bikes are generally so reliable that doesn't happen.
post #5 of 8 Old 04-26-2019, 12:38 PM
OCADVR's Avatar
Mine works fine with LED brake light "bulbs" plus an auxiliary LED brake light. Even so, one can't tell if the LEDs or bulbs are working at any given time but I figure most likely only one of the three will fail unless the signal itself is not getting to the LEDs. To tell if the brake light signal is working, I ran a wire to a small LED on my dash that lights up when the brake light signal is working. And, because the modulator is electronic and subject to fail, I have 2 switches under the seat to switch between the 2 different styles of modulation or to bypass the modulator altogether should it fail.
I know it sounds complicated but it works for me. YMMV
P.S. This is from the Signal Dynamics info, "This module is designed to work with standard incandescent brake lights, LED brake lights, or a combination of both"
Jack
SoCal 92691
OCADVR is offline
post #6 of 8 Old 04-26-2019, 12:58 PM
Naffle's Avatar
+2 on these. Mine should be here today, getting installed this weekend..
Naffle is offline
post #7 of 8 Old 04-26-2019, 04:51 PM
RCE1's Avatar
Is there a way to install this device without taking the back end of the bike apart? I tried a different brand and couldn't find a good way to put it in, so I shelved the project.
RCE1 is offline
post #8 of 8 Old 04-27-2019, 06:23 AM
om28's Avatar
I've been using the these for years, a super easy install, they come in halogen or LED. Blink 3 times when you hit the brake and then stay on.
https://kisantech.com/20w-d2pak.html
2009 Wee Strom ABS (current)
1987 Harley Low Rider Sport (current with 200K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles in order of importance: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
How much gas is left when 1 bar starts blinking? America First DL650A - 2017+ 17 02-14-2019 02:37 PM
Blinking LEDs keetmanaa General V-Strom Discussion 3 12-07-2013 08:02 AM
Fuel light starts blinking with 1.5 gallons to spare? arooni General V-Strom Discussion 21 11-27-2012 01:18 PM
FI with blinking red...oh s***, need 'dealer mode' jra-xp DL650 and DL650A - 2004 to 2011 19 07-21-2008 11:52 PM
multiple falls = Blinking FI light PDXStrom General V-Strom Discussion 16 03-04-2008 10:22 AM
