Front shock advice - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By Solo
  • 2 Post By blaustrom
  • 1 Post By om28
post #1 of 8 Old 04-19-2019, 11:18 AM Thread Starter
Front shock advice
I am about to change my tires on my 2009 DL 650 with 65k miles and figure it would be a good time to do any needed work on the front suspension. None has been done before. I haven't noticed any issues, but this is really the only bike I have ridden so I don't have much to compare it to. A couple of years ago one of the tubes was leaking, but I tried the thing with the film negative and it stopped.
Should I just have the shop change the oil in the tubes, or is there something else you guys would recommend?
BugSlayer is offline
post #2 of 8 Old 04-19-2019, 12:03 PM
I would change the fork oil at a minimum and perhaps the seals to.
Lots you can do to improve the front suspension if that's the route you want to go. There is a current discussion going on in this thread that might give you some ideas on maintenance and upgrading.
https://www.stromtrooper.com/dl650-d...intenance.html
gdrew is offline
post #3 of 8 Old 04-19-2019, 01:25 PM
You might want to do it yourself. Here's a good sight for tutorials.
https://blacklabadventures.com/2012/...nt-fork-seals/
Martin likes this.
2007 DL 650 with assorted upgrades
Solo is offline
post #4 of 8 Old 04-19-2019, 02:28 PM
blaustrom's Avatar
If you work on it change the seals and the bushings. You will be shocked how bad the fork fluid coming out is. And its likely low making the fork air cushion bigger than as per design.
I would get some Intiminator drop in devices and you will be amazed how much nicer your front is after that change. Bad part is then you will want the rear shock improved as well.
NateHarris and Gert like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 8 Old 04-19-2019, 04:44 PM
Big Boy's Avatar
If you don't want to do the work yourself, I suggest sending your forks to Daughtery Motosports. Highly recommended. DMr Performance Suspension ? Performance Motorcycle Suspension and Chassis He does any and all types of suspension work and can rework your forks to fit your weight and how you ride.
W. C. Fields
Big Boy is offline
post #6 of 8 Old 04-20-2019, 06:58 AM
om28's Avatar
Yes, fluid at a minimum. I replaced bushings (along with fluid &seals) at around 35K miles since the forks had developed a harsh ride. Now it's at 75K miles and riding harsh again so I'll be rebuilding the forks today.
What I've discovered with suspension upgrades after doing more than I care to admit, is if you don't notice a problem you don't need an upgrade. I only found the Elka shock to be slightly better than stock, but every other upgrade was no better, or was worse than stock. I must be the model rider that the OEM's tune their suspension to.
Motorpsychology likes this.
2009 Wee Strom ABS (current)
1987 Harley Low Rider Sport (current with 200K miles)
2009 Aprilia Mana 850, 2006 SV650, 1984 Yamaha Virago 1000 (all sold)
Silver Strom Club Member #11
Wee Farkles in order of importance: Russell Day Long Seat, Madstad with Moose Adventure Shield +4'', SWMotech Centerstand, Givi XS308 Tankbag, Aprilia mirrors, Framesliders, Fenda Extenda, Elka Shock.
om28 is offline
post #7 of 8 Old 04-21-2019, 09:30 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Me personally, if the seals are not leaking I would not replace them yet. Many bikes go much longer than yours with the stock seals. If your the kind of guy that likes doing maintenance go for it, but I would wait. You might want to check out Sonic Springs site and their spring rate calculator. Having the right spring rate can dramatically improve the bike. There is a spring rate calculator ion the site that takes into account yourt weight and riding style and some otehr factors. . The right springs can transform a DL650 into a very competent sport touring bike and they don't cost much. I paid less than $100 for my fork springs a few years back.
Sonic Springs
richlandrick is offline
post #8 of 8 Old 04-21-2019, 04:29 PM
gt750's Avatar
If you are NOT having any issues why change anything? You'll know when there is an issue. At most, drain and refill the fork oil.
I have an 07' model 650 and think it is the springs are too light for me, as well as having poor damping characteristics. It's works well for it's intended purpose though. For about $450.00 it can be made better with Race Tech Cartridge Emulators, springs, fresh oil and new teflon bushings.
gt750 is online now
GStrom DL650AL3 2013 Front Fairing Cowl Install / Removal TheSheep DL650A - 2012-2016 1 12-25-2015 08:49 AM
Front disc brake lock mishap-need advice Soundman General V-Strom Discussion 9 11-20-2015 10:49 AM
Aftermarket Shock Fit? Coast range rider DL1000A - 2014-2016 8 04-26-2014 12:02 AM
Front Fender Cracking Fix(?) Vangky DL650A - 2012-2016 8 03-04-2014 02:18 PM
Front spark plug removal advice ElBando General V-Strom Discussion 4 01-24-2010 05:51 PM
