bogging to 3500 rpm - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By blaustrom
post #1 of 9 Old 04-12-2019, 07:17 PM Thread Starter
Location: Kind of live in bc, but back to Nomad. No home.
bogging to 3500 rpm
Hello, so, I've had this weird bogging problem that's been developing with strom 04 650. It feels like there's water in gas up to 3500 rpm(always 3500 now), then it pulls like it normally does from there on in. All shims for valves are within spec, fuel pump has bypass with car filter. Hoses look good. New spark plugs. Feels like a vac leak? Haven't synced the throttle in a while, probably due. Ideas for the weird bog? Thinking look at tps based on searches.
No water in gas, gas swapped.
Sexyman is offline
post #2 of 9 Old 04-12-2019, 08:31 PM
Administrator
Could be bad injector, believe was similar symptoms and issues with another trooper recently?
2015 DL650 XT "Fred"
1997 Honda Valkyrie 1500 custom “Fiona”
post #3 of 9 Old 04-12-2019, 08:54 PM
My '04 runs like new, I think. No issues about how it runs and I'm at 97K miles. Gas and go. Have you done some tune ups? I ain't done shit since I got the bike. Less is mo bettah, maybe?
post #4 of 9 Old 04-12-2019, 11:02 PM
blaustrom's Avatar
Originally Posted by Sexyman View Post
.... Feels like a vac leak? Haven't synced the throttle in a while, probably due .... Thinking look at tps based on searches....
I like these checkpoints.
There are cups plugging the vacuum lines used for throttle sync. Sync them and make sure these plugs are in good shape.
Can't hurt to run some Seafoam or something similar through the tank, in case it's an injector problem, it may help.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #5 of 9 Old 04-12-2019, 11:10 PM
My DL 1000 had a similar issue. It turned out to be corroded electrical connections.
Streeter is offline
post #6 of 9 Old 04-13-2019, 09:40 AM
V-Tom's Avatar
In addition to the spark plug cap check mentioned previously here are a couple of simple things to check:
Have you washed the bike or ridden in rain lately? There is a drain hole in the front spark plug hole that can get plugged and hold water in there. This can cause lower speed misfiring and lack of power. The hole exits on the right side of the engine iirc.
Do you have a voltmeter on the bike? Are the batter terminals done snugly? Low voltage (bad stator can be a cause) or loose batter cable can cause enough voltage drop at low revs to cause misfiring.
..Tom
2015 DL1000 New July 2015 160,000+ km, 100,000+ miles.
SMIDSY detailed report.
V-Tom is online now
post #7 of 9 Old 04-13-2019, 02:57 PM
Has the base idle changed? Does it do this every time? If you answered no I'm suspicious of the lower TPS.
When mine started acting up I did several resistance sweeps, never saw a hiccup. So I threw one at it, anyway. Fixed. What I'm saying is the testing was inconclusive. It tested fine, although some will fail test. Many things were considered before I threw $100.00 at it.
2007 DL 650 with assorted upgrades
Solo is offline
post #8 of 9 Old 04-13-2019, 05:23 PM Thread Starter
I'm at 94000 km on bike, this is a new issue. I'll check what you guys mentioned and get back to you.
It's been stored in enclosed trailer for winter. No rain.
Sexyman is offline
post #9 of 9 Old 04-14-2019, 12:20 AM
blaustrom's Avatar
How about a critter in the airbox or the throttle body bellows chewed on?
V-Tom likes this.
Blau2 2014 DL1000A
Grinding Sound at 3500 rpm Dusty R. DL650 and DL650A - 2004 to 2011 4 02-17-2019 09:39 PM
No power between 3500 and 4000 RPM DrunkMonkey2304 DL1000 from 2002-2012 22 07-22-2017 06:42 PM
Front Sprocket Change - 3500 Miles johno_SLC DL650 and DL650A - 2004 to 2011 9 05-30-2016 03:56 AM
'09 DL650 Bogging Down MetalMariner DL650 and DL650A - 2004 to 2011 19 04-03-2014 06:48 PM
mud bogging Toddstrom General V-Strom Discussion 3 02-25-2014 09:57 PM
