Silly question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 12 Old 04-08-2019, 10:32 AM Thread Starter
Silly question
Hello-
Im new here to the Vstrom. Just picked up a 2005 650. Silly question but does anyone know what type of bulb is used in the turn signals. I do not have a owners manual.
Thanks
jdervish is offline
post #2 of 12 Old 04-08-2019, 10:58 AM
eff
eff's Avatar
You can look up OEM parts on a number of websites, like https://www.rockymountainatvmc.com/oem-schematic/
The Suzuki part is 09471-12045 12V 21W bulb. It may be a 1156 automotive bulb but I can't confirm that, but i did see that on another forum.
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #3 of 12 Old 04-08-2019, 11:26 AM
PerazziMx14's Avatar
Easy enough to pop the lens off and have a look.
blaustrom, notacop and gdrew like this.
PerazziMx14 is offline
post #4 of 12 Old 04-08-2019, 11:59 AM
blaustrom's Avatar
Look what you have. If it's stock its a regular single filament indicator bulb.
Replace them with high intensity LED's and a new flasher relay and people will actually see where you are indicating!
Motorpsychology likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #5 of 12 Old 04-08-2019, 05:28 PM
Stalky Tracker's Avatar
Welcome to the forum, jdervish.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #6 of 12 Old 04-08-2019, 09:04 PM
Brockie's Avatar
The part number 09471-12045 is correct, however it is a specialty bulb marked 2CT 12v 21w 9H3. With clear lenses (are yours clear?) the bulb is amber colored glass.
It is otherwise the same as a 1156 bulb, but that would mean you would have white indicators, which is surely illegal.
notacop likes this.
Brockie is offline
post #7 of 12 Old 04-09-2019, 03:05 AM
Gert's Avatar
If the indicator lenz cover is stock like my K5, then the lens is amber. The bulb is clear, not an amber color. The lens cover has screws hold it in place. As Brockie posted, the bulb is 12V 21W, as used in indicators on most cagers.
V-Tom likes this.
Gert is offline
post #8 of 12 Old 04-09-2019, 09:17 AM
Brockie's Avatar
I've checked further and the clear lenses/coloured bulb was only introduced with the K9 model of 2009. Previous models had clear blubs.
V-Tom likes this.
Brockie is offline
post #9 of 12 Old 04-09-2019, 10:35 AM
sweater's Avatar
...yeah, I tried to search a bit here but couldn't directly find this. Want to swap out both turn signals and headlights but cannot find info on what bulbs would fit (that'll be easy to find) but more importantly what I'd need as far as an LED-compatible relay. You don't happen to have somewhere I can look into that more, do you?
- mike
2007 DL650 | 2007 CRF50F
sweater is offline
post #10 of 12 Old 04-09-2019, 01:36 PM
blaustrom's Avatar
https://www.google.com/search?client...+flasher+relay
Bulb: I would go with this style, you need to search where to get it here ..
https://www.classiccarleds.co.uk/pro...s-ba15s-glb382
Blau2 2014 DL1000A
wiring a ground question chetc General V-Strom Discussion 7 11-16-2012 05:38 PM
Silly question ?? sasquatch DL650 and DL650A - 2004 to 2011 6 08-30-2012 12:12 PM
Dirt, gravel and mud question TheWall DL650 and DL650A - 2004 to 2011 19 06-02-2012 10:11 AM
silly bolt size question Arne DL650 and DL650A - 2004 to 2011 0 02-10-2012 10:13 PM
Buffeting.....newbie silly question..... Spartan General V-Strom Discussion 10 06-23-2011 12:27 PM
