put dl1000 hydraulic clutch on dl650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #1 of 21 Old 04-05-2019, 06:49 PM Thread Starter
Lightbulb put dl1000 hydraulic clutch on dl650?
I am an old person running around on a dl650 and in town I do an awful lot of clutching and shifting. nothing on this old person works as good as it used to, including hands. I have had bikes with a hydraulic clutch before and they are much easier to operate than the old cable operated clutch.
on ebay I ran across a complete dl1000 clutch operating set up, master cylinder, hyd line, and slave cylinder. It looks like it would work, might have to slot the holes. Has anyone done this transplant? If it will work it would be great for me.
I think I should make it clear that what I am after is not the dl1000 clutch pack itself , but the hydraulic actuation mechanism. Magura makes a hydraulic conversion for dirt bikes for $300 but it uses a hydraulic cylinder to operate the conventional mechanical clutch release mechanism and that has a lot more inefficiency than a straight hydraulic mechanism
RLBranson is offline
post #2 of 21 Old 04-05-2019, 07:06 PM
STCorndog's Avatar
I do not think a DL1000 clutch is going to do you any good. I would be looking into either a dirt bike type conversion for changing cable clutches to hydraulic or possibly using softer clutch springs (if you are not a heavy throttle user).
pvwheeler likes this.
STCorndog is offline
post #3 of 21 Old 04-05-2019, 07:15 PM
OCADVR's Avatar
I have seen a hydraulic clutch conversion kit for the Wee but it costs about $300. I can't remember the brand off the top of my head. I'll see if I can find it a little later if you're interested at that price.
Jack
SoCal 92691
"I feel more like I do now than I did a while ago."
OCADVR is offline
post #4 of 21 Old 04-05-2019, 07:50 PM
Rolex's Avatar
If you plan on keeping the bike a Rekluse auto clutch could be worth the investment.
pvwheeler and Spec like this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 21 Old 04-05-2019, 08:18 PM
Brockie's Avatar
I would think that mounting the slave cylinder would be a very challenging engineering achievement.
Ensure that the clutch cable adjustment, the clutch adjustment, and the clutch cable and lever action are as good as they can be.
Then consider this: https://www.ebay.com/itm/Moose-ATV-D...-/163334093720
Or this: https://www.aliexpress.com/item/1200...808616920.html
Brockie is offline
post #6 of 21 Old 04-05-2019, 11:54 PM
OCADVR's Avatar
Magura is the hydraulic clutch kit that I saw but it looks like you're already aware of them.
Jack
SoCal 92691
OCADVR is offline
post #7 of 21 Old 04-06-2019, 10:39 AM
Administrator
My 650 cable clutch is easier than either of the 1000 Stroms I owned, so hearing you are wanting to move to hydraulic really surprises me.
2015 DL650 XT "Fred"
1997 Honda Valkyrie 1500 custom “Fiona”
post #8 of 21 Old 04-06-2019, 11:52 AM
It is not the "hydraulic vs cable" that makes a DL 1000 different in pull. If a DL 1000 had a cable clutch, it would probably be even harder to pull and go through cables fairly often. DL 1000's have extremely strong pressure plate springs.
DL 650's have a nice clutch lever pull when everything is right.
I have tried some off the wall stuff, but the work to try to mount a DL 1000 slave cylinder to the 650 is something I would never try.
Get an EFM auto clutch, or a Rekluse auto clutch if lever pull is a problem.
Big B likes this.
realshelby is offline
post #9 of 21 Old 04-06-2019, 01:44 PM Thread Starter
Some real good thoughts here. thanks much guys. The reason that it occurred to me to put a dl1000 slave cylinder on my 650 is that I ran across one on ebay a couple days after moving the 650 clutch actuator out of the way to put a 16 t front sprocket on. ( love the 16 ) the image of the 650 actuator is fresh in my mind and it sure looks like the dl1000 would bolt right in and do the job. an advantage to using the 1000 master cylinder/lever assy is that a mirror mounts on it which the magura doesn't have.
I occasionally run across a kawi zrx1200 that I used to own. the hyd clutch lever on that 1200 is easier for me to pull in than the clutch lever on my dl650. hydraulic is a good thing. Auto clutches are the wave of the future I'm sure.
post #10 of 21 Old 04-06-2019, 03:02 PM
"Bolt right in" is the key. There are no bosses cast into the 650 engine cases to mount the DL 1000 slave cylinder to! That would be a major project involving aluminum welding to make happen. Welding that would probably include engine disassembly to do it right.
IF you could get the DL 1000 slave cylinder mounted, then a bit of fabrication would allow the pushrod to work without much effort.
Big B likes this.
ThanksGiving with All the Fall Farkles and Great Upgrades for DL650 and DL1000 Models SV Racing Parts SV Racing Parts 1 11-15-2018 11:56 PM
The 4th of July, Summer, and 2018 Farkles and Great Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 1 07-01-2018 01:46 PM
2018 Summer Riding Farkles and Great Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 1 06-01-2018 11:57 AM
DL1000 vs DL650 rear shock Judd Maintenance, Tech and Products. 1 01-19-2010 08:49 AM
