put dl1000 hydraulic clutch on dl650? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #11 of 21 Old 04-06-2019, 04:37 PM
How much force is required to get the clutch plates to separate, and how much force is wasted on friction in the clutch cable? With these modern teflon coated cables my gut feeling is that maybe only 10% of the force is due to friction. That's what you can potentially eliminate with a hydraulic clutch of a DL1000. Because the DL1000 hydraulic clutch is just that - a hydraulic system instead of a cable operated system. It's not a "power clutch" as in "power steering" or "power brakes". There is no energy of the engine going into the system to make clutch operation easier.
BackPacker is offline
post #12 of 21 Old 04-06-2019, 05:08 PM Thread Starter
There are bosses cast into the 650 case that the mechanical actuator bolts to. the slave cylinder would bolt there, to the existing bosses IF it is a perfect fit. In the meantime I think I will lengthen the arm that the cable pulls on by about 1/4". it is a short arm compared to the longer clutch actuating arms that we used to lengthen by 1/2" on some early motorcycles. before I lengthen the arm (retired welder here) I would like to get a fish weighing scale to see what kind of pull is required before and after the modification. so I will be held up until I get a fish weighing scale.
vegashotwheeler likes this.
RLBranson is offline
post #13 of 21 Old 04-06-2019, 07:18 PM
Motorpsychology's Avatar
Originally Posted by RLBranson View Post
I am an old person running around on a dl650 and in town I do an awful lot of clutching and shifting. nothing on this old person works as good as it used to, including hands.
Me too, R.L.
Arthritis is starting to set in, and, although the clutch on my bike is tolerable for now, I do miss the hydraulic clutch of my previous bike. I shift up clutchless from 3rd thru 6th and down 6th to 5th. Also, I find I don't need to pull the clutch lever all the way back except for initial launch,
I'm not as good as I once was, but I'm as good once as I ever was
Big B likes this.
18 wheels move the cargo, 4 wheels move the body, 2 wheels move the soul -unknown
“Of all the paths you take in life, make sure a few of them are dirt.” - John Muir
I visited the Air & Space Museum- didn't see a thing...
Motorpsychology is offline
post #14 of 21 Old 04-06-2019, 07:34 PM
I've always been impressed with the clutch function on the DL650 -- easily the nicest cable-operated clutch I've ever used. If there's a problem with your cable or actuating mechanism, those are pretty easy fixes.
If a clutch like the V-Strom's is giving you trouble, you might consider a DCT like the Honda NC700 / 750x. The bike has a strong following, and it's common to find them used with extremely (troubling, maybe) low miles. I've been considering a 2016 NC700X myself.
Big B, pvwheeler and Hatchi like this.
RobertBarr is offline
post #15 of 21 Old 04-06-2019, 08:44 PM
Brockie's Avatar
Have you ever considered adjustable levers? Perhaps moving the engagement point may assist.
BTW some Suzuki hydraulic clutches seem to have an overly large master cylinder internal diameter and a tendency to engage abruptly at almost full release, a tendency that would be a disadvantage to those with hand issues.
There is a discussion thread on the DL1000 hydraulic clutch here: https://www.stromtrooper.com/dl1000-...djustment.html
Brockie is offline
post #16 of 21 Old 04-06-2019, 09:02 PM
Macdoc's Avatar
Have you looked at the Easy Pull systems....
Moose Easy Pull Clutch System
There are several all working on the same principle. I almost bought one then switched to a Honda with a lighter clutch.
A good solution for a heavy clutch
I bought and installed this system a month ago on my Suzuki dr650 and it's worked well so far. I commute to work in the city and was getting a sore wrist after 20 mins of stop and go so I picked this up as a cheap solution. Haven't had any pain since. Was easy to install but would recommend putting some grease inside as well as sealing with silicone or something as it's not waterproof. Installation took about 20 minutes. I docked 1 star because it came with zero instructions but you should be able to figure it out. It also gives you a longer pull so let's you modulate clutch engagement more precisely which can be good for launching from a stop or slow speed maneuvers. Highly recommended
Enthusiast (daily)
2003 dr650se
They seemed to be marketed to dirt bikes but it's a simple principle and no reason not to work on the Vstrom......easier and way cheaper.
Canada 2018 CB500x >2009 CBF1000 sold • 10 Wee ABS sold • 09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR650 • 93 ST1100 sold •
Macdoc is online now
post #17 of 21 Old 04-07-2019, 02:50 AM
Gert's Avatar
Gert is offline
post #18 of 21 Old 04-07-2019, 03:04 AM
Rolex's Avatar
When my young bloke was 6 or 7 he had a KX80 and I fitted a Easy Pull clutch.
While it did ease some of the load it did also reduce some of the movement of the actuating arm meaning I had to have zero slack in the cable to get the clutch to function, having zero slack puts plate slip at risk.
Have you had a look at your clutch basket ?
They wear low points on the outer basket were the plates ride so when you pull on the leaver the plates must ride up onto the high points to separate.
Smoothing out the high points will make the clutch action easier and smoother, it is free to do and I would give it a try if I was in your position.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #19 of 21 Old 04-08-2019, 09:44 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Following.
After about 5 miles of what I call power walking (continuous pulling and releasing clutch moving bike a few feet at a time) bike in construction traffic in Vegas the other day.
My hands are still killing me, the whole section was on an incline so had to ride brake too.
I would be interested in a improvement in the pull, but was very glad I was on my 650 instead of my 1000 because it is a much easier pull on the 650.
I need to get back in the habit of squeezing a stress ball or similar to build up hands while watching tv.
Used to have one on my desk and would use it when I thought about it, also not so dangerous when coworker stressed me and I threw it at him 😉
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #20 of 21 Old 04-09-2019, 03:34 AM
Strange Dog's Avatar
Have you tried pulling the clutch lever on someone else's DL650 to see if it is just your bike? The lightness of my Wee's clutch is one of the things I really like about the bike, yours may be defective?
Big B and realshelby like this.
[URL=http://www.fuelly.com/motorcycle/suzuki/dl650_v-strom/2011/strangedog/493573][IMG]http://badges.fuelly.com/images/sig-us/493573.png[/IMG][/URL]
[URL=http://www.fuelly.com/motorcycle/suzuki/dl650_v-strom/2006/strangedog/401455][IMG]http://badges.fuelly.com/images/sig-us/401455.png[/IMG][/URL]
Strange Dog is offline
ThanksGiving with All the Fall Farkles and Great Upgrades for DL650 and DL1000 Models SV Racing Parts SV Racing Parts 1 11-15-2018 11:56 PM
The 4th of July, Summer, and 2018 Farkles and Great Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 1 07-01-2018 01:46 PM
2018 Summer Riding Farkles and Great Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 1 06-01-2018 11:57 AM
DL1000 vs DL650 rear shock Judd Maintenance, Tech and Products. 1 01-19-2010 08:49 AM
