2008 DL650 - Idles fine, dies on revs > Help please! - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #21 of 25 Old 04-20-2019, 10:37 PM
Stalky Tracker's Avatar
Originally Posted by rudolfs001 View Post
Where can I buy plugs or end caps for the hoses/nozzles? I checked Lowes, but they don't have anything small enough.
I got mine at Auto Zone or Advanced Auto, don't remember which. They were Dorman Products "vacuum caps" and probably can be found on-line too.
Oh, forgot, if you need them on the end of a hose, use "vacuum tubing connectors" and then the cap.
2019 Eastern V-Strom Rally (website) - May 16 - 19, 2019
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #22 of 25 Old 04-24-2019, 12:21 AM Thread Starter
Went to Auto Zone and picked up some vacuum caps.
I capped the nipple on the tank that leads to the carbon canister. The line going from the canister to the throttle bodies was made of two tubes, connected by a vacuum tubing connector. I disconnected them and capped the end going to the throttle body.
1. There was definitely a lot of gas in the carbon canister
2. The bike ran perfectly after capping those two lines
So there you have it, it was gas in the carbon canister all along, causing all kinds of vacuum issues. I suspect the tube in the tank is cracked and letting in gas, but didn't take the tank apart to check. It doesn't seem worth it. Any reason I should?
Gert and Hatchi like this.
rudolfs001 is offline
post #23 of 25 Old 04-24-2019, 09:07 AM
Glad to hear it's running "perfectly". For now, keep an eye on if the tank needs to be vented. As mentioned in the post it was not determined if the tank needs to now be vented. Sounds like CA emissions have a sealed tank system.
Mikeys is offline
post #24 of 25 Old 04-24-2019, 08:49 PM Thread Starter
How can I check if the tank is vented or if I'll need to replace it with a vented tank/cap?
post #25 of 25 Old 04-24-2019, 11:27 PM
The CA emissions are suppose to be "sealed". So by plugging the system off,, the tank "should" be non vented. Possibly creating a vacuum as the fuel is used. If you read the post I attached, bdesj vented his cap but was not sure if it was needed. If you have any questions, I would PM him and see what he thinks or how he vented the cap or maybe just driving it for a while and pop the cap and see if it has created a vacuum.
Mikeys is offline
Electrical Issues 2008 dl650 Pinguin Balo DL650 and DL650A - 2004 to 2011 5 06-15-2016 02:45 PM
2008 DL650 Tranny failure? lakejimmyjon DL650 and DL650A - 2004 to 2011 17 04-23-2016 12:43 AM
2011 DL650 to dies on hot days after it starts and idles well CPT Wade DL650 and DL650A - 2004 to 2011 16 02-23-2016 12:03 PM
SV650 front wheel installation on a DL650 exploring/carolina V-Strom Modifications and Performance 53 06-12-2014 02:54 PM
