Headlights flickering and battery drainoon - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 2 Post By blaustrom
  • 1 Post By Motorpsychology
post #1 of 5 Old 03-29-2019, 06:33 PM Thread Starter
Hi all,
Just bought a 08 650. It's a bit rough but I'm willing to put the time into it. I had to put in a new stator straight away, while I was at it I put in a new regulator also.
Since putting it back together it ran perfect for about 48hrs until my lights started flickering while I was driving it home from a buddies at night. They only die for a second before coming back on again but enough to make the butt clench. I've checked the plugs and all seem ok, any ideas?
Separately, I left the bike sit for for 24hrs, Killswitch on, when I went to start it the bike the turned over once and died. Checked the battery and it was at 11V roughly. Charged it up, started first pick and checked it running in case my stator install was the cause but it was charging. Now the bike has an alarm and a immobiliser. I'm convinced it the alarm so is this something I have to live with?
Apologies for the long post and thanks in advance!
Smurphdamurph is offline
post #2 of 5 Old 03-29-2019, 07:37 PM
Can you give us the following voltages, measured across the battery terminals:
- Bike off, having sat for a while
- Ignition on, lights on, not started
- Bike started, idle
- Bike started, 3000 RPM
- Bike started, 5000 RPM
If possible, unplug the R/R and perform the stator test. Just because you changed it doesn't mean it's good.
- Resistance (ohms) between each wire pair
- AC voltage between each wire pair at idle, 3000 and 5000 RPM
What was the reason for putting in a new regulator? These are not really known to fail. What regulator did you put in?
When you did put the stator in, did you inspect the rotor magnets? Even spacing all around?
BackPacker is offline
post #3 of 5 Old 03-29-2019, 10:21 PM
blaustrom's Avatar
Add to the information mileage of the bike.
What makes you think that the lights, assume you are talking about the headlights, have anything to do with the spark plug function?
With all the changes made to the bike, does it have headlight relays installed or not? If not check the starter switch for burned contacts. The headlight power is routed through that switch and the >100W draw of the 2 headlights is too much current for that witch. If that switch is nice and clean check the main electrical connector on the left side of the fairing for burned or corroded contacts.
Let us know what you find.
Gert and Hatchi like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 5 Old 03-30-2019, 10:32 AM
I'm slow but I finally got some digital volt meters for the bikes that cost a couple bucks apiece with free shipping. Now I can see exactly what the charging system is doing as i ride.
notacop is online now
post #5 of 5 Old 03-30-2019, 11:03 AM
Motorpsychology's Avatar
I think blaustrom could have meant "connectors" not "plugs."
Warhead likes this.
18 wheels move the cargo, 4 wheels move the body, 2 wheels move the soul -unknown
People who confuse the words "burro" and "burrow" don't know their ass from hole in the ground
Motorpsychology is online now
Found out what happens when your battery dies on the freeway hobbyist DL650 and DL650A - 2004 to 2011 35 12-08-2017 12:22 AM
Does this mean I have a bad battery? levsmith General V-Strom Discussion 6 08-13-2014 09:13 PM
Drained battery? DuffManG V-Strom Service and Maintenance Questions and Discussions 13 04-16-2011 07:05 PM
