‘04 650 countershaft seal leaking - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 03-27-2019, 01:07 PM Thread Starter
DF37BAFC-9A74-4556-B95E-0ADF3769ED54_1553706431723.jpg I have an oil leak, I just can’t stand anymore. It was doing a fantastic job of auto-oiling my chain, but making a horrible mess. Took me a bit to track it down, but it appears to be coming from the countershaft seal behind the front sprocket.
I’ve replaced a few of these on KTM 2-strokes, and my DRZ, but wanted to consult the Strom masses before I order replacements.
‘04 650. Should I try just replacing this o-ring? Number 20 in the diagram? Or the oil seal as well number 21?
When I’ve removed the seal on other bikes, I used the drill and sheet metal screw method. Anyone have experience removing this seal?
Thanks for your Inputs.
File Type: jpg 0C55EC1E-49DC-44CD-96E5-CB0C31DA2D72_1553706446664.jpg (206.1 KB, 6 views)
File Type: jpg 61E71984-7C37-4675-B384-2312F7343544_1553706458259.jpg (413.2 KB, 7 views)
Psycho18th is offline
post #2 of 4 Old 03-27-2019, 04:10 PM
I posted on the other forum.
I wouldn't consider NOT replacing O-ring and seal. That piece in your hand... Be sure there's no groove worn into it where the seal rides. If so, replace it.
2007 DL 650 with assorted upgrades
Solo is offline
post #3 of 4 Old 03-28-2019, 03:08 AM
Gert's Avatar
Have you perhaps read this write up https://blacklabadventures.com/2012/...tershaft-seal/
Gert is offline
post #4 of 4 Old 03-28-2019, 10:34 AM Thread Starter
Yes! Found that one yesterday. Good stuff.
Leaking Under (not the hose) Water Pump After Mechanical Seal Replacement Kerem Poyraz DL650 and DL650A - 2004 to 2011 2 06-21-2017 02:05 PM
Replacing Clutch Push Rod Seal and Countershaft Seal mongooseknight Maintenance, Tech and Products. 2 04-19-2017 12:26 PM
Oil Seal for clutch push rod leaking lilzip24 DL1000A - 2014-2016 22 07-11-2016 03:54 AM
Countershaft seal litespeed602 DL1000 from 2002-2012 3 10-16-2013 05:02 PM
