Occasional Flat spot on acceleration? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-20-2019, 07:03 AM Thread Starter
Question Occasional Flat spot on acceleration?
So I have done the muffler mod where you take out a small bit of the baffle and I must say I love the sound of it. It gives it a nice bark without sounding too loud.... ANYWAY.
I have noticed a very small hesitation on take off once and a while, I assume due to the change in back pressure in the exhaust system. Does anyone know of a way to fix this, I heard someone has something called a "Spark Arrester" but I have no idea what that does.
Anyway, looking forward to hearing from you all.
Thanks in advance.
Jon
propainkiller87 is offline
post #2 of 6 Old 03-20-2019, 09:12 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
A spark arestor is just a perforated plate or more often a screen intended to catch hot carbon that my blow out the exhaust and start a fire. they are required for all motorcycle used in national forests. Forest rangers check for the presence of a spark arestor by inserting a rod into the exhaust. They expect to meet resistance within a certain depth of insertion.
They are designed to be as free flowing as possible, so not likely a solution to your problem.
I expect you are a little lean at and near idle now. These bikes are a little lean anyway fro the factory and now yours is a little leaner. Either live with it or install a FI controller like a PCFC or similar.
richlandrick is offline
post #3 of 6 Old 03-20-2019, 03:11 PM
Rolex's Avatar
Is your clutch switch working as it should and do you notice any difference between a hot or cold motor ??
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 6 Old 03-20-2019, 03:19 PM
Fox
Fox's Avatar
If it gets worse, you could look at the fuel filter. Mine started giving me problems at wide throttle openings, and got worse as it continued to clog.
Fox is offline
post #5 of 6 Old 03-21-2019, 03:34 AM
Gert's Avatar
Gert is offline
post #6 of 6 Old 03-28-2019, 09:03 AM Thread Starter
I've never had a starting issue, Wide open throttle pulls hard the whole way with no hesitation. as for tps setting, I have not checked that yet, the clutch sensor is working as well.
Flat Spot Billyjc DL1000 from 2002-2012 23 12-22-2015 07:07 PM
oxford heated grips flat spot Knobby Bob DL650A - 2012-2016 3 02-08-2015 06:14 PM
Flat tire repair story/question bandroidx DL650A - 2012-2016 35 07-11-2014 05:28 PM
Flat spot @ 6k and cutting out at lights Alanjnr Maintenance, Tech and Products. 1 07-20-2013 06:58 AM
SPOT satilite richw General V-Strom Discussion 11 05-05-2013 10:06 AM
