Dead 2011 WeeStrom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 03-18-2019, 08:52 PM Thread Starter
Dead 2011 WeeStrom
Battery died, left the handwarmers on. Jumped it with a car battery and jumper cables (had no choice). It started right up took off. About a minute later the speedo, tach, and center gauge went haywire. The bike bucked. It stalled out and died. What did I do and what do I need to fix?
scanino is offline
post #2 of 11 Old 03-18-2019, 09:04 PM
ddphillips's Avatar
When my battery went completely flat i had to rotate the throttle open closed to re-calibrate the tps, but mine would not start till i did this, yours started, does yours start now, is the battery taking charge?
Darren
2017xt 650 vstrom, yellow.
Ohlins SU216 rear shock, .85 fork springs, cogent DDC, Barret 3/4 exhaust, 20mm rear raising links, ricks fork brace, oxford heated grips, Radguard, Altrider bash plate & engine bars, Steel pony soft panniers and rack, TAG bars, foot peg lowering brackets, gear lever extension, bar end mirrors.
ddphillips is offline
post #3 of 11 Old 03-18-2019, 09:10 PM Thread Starter
I'm waiting for my friend to get here so I can jump it. I will have to wait until I get home before I can see if it takes a charge.
scanino is offline
post #4 of 11 Old 03-18-2019, 10:50 PM
Hopefully the car wasn't running when you jumped it?
Warhead likes this.
post #5 of 11 Old 03-18-2019, 11:09 PM Thread Starter
It was running.
scanino is offline
post #6 of 11 Old 03-19-2019, 02:14 AM
ddphillips's Avatar
Car running should be ok, DC voltage would be around 14Vdc, but if the bike battery is dead, not charging, high internal impedance, the DC from the bike could be noisy- the battery helps keep the DC voltage smooth, noise on the 12Vdc could well upset the ECU.
Darren
post #7 of 11 Old 03-19-2019, 02:23 AM
I’ll allow those who know more than me to correct if I’m wrong, but I have heard to NEVER jump a motorcycle battery off a car or truck battery when it’s running.....only jump battery to battery.
post #8 of 11 Old 03-19-2019, 03:58 AM
ddphillips's Avatar
Assuming both bike and car/truck have 12v systems then both will have very similar running/not running DC voltages, when running both around 14v, not running both around 12.8v, assuming batteries are ok. Assuming no faults with the bike it will draw what current it needs for the starter motor, fuel pump ecu etc. if there is a fault with the bike the car battery will deliver more fault current wether the car is running or not. Alternator outputs these days are well regulated, ie output voltage won’t change much more than a few hundred millivolts idling or revving.
Can we assume the bike was disconnected from the car after the bike was started and then it ran poorly/stalled, if so then probably failed bike battery,
Darren
post #9 of 11 Old 03-20-2019, 08:12 AM
Warhead's Avatar
Sounds like a new battery is needed. My 2009 did the exact same thing. I would have to jump it but I could only make it a few hundred meters before the gauges did the dance and then it died. A new battery did the trick. When the auto parts store (Canadian tire) load tested the battery it only had 50ish CCA. our best guess is that a section of cells collapsed. Because the battery would show proper voltage but without being jumped it wouldn't power a thing.
madscrapper85 likes this.
Don't drop your bike after owning it for 3 hours.
Warhead is offline
post #10 of 11 Old 03-20-2019, 01:35 PM Thread Starter
I changed the battery problem solved. Thanks everybody.
scanino is offline
