Galfer brake lines. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #1 of 16 Old 03-18-2019, 04:42 PM Thread Starter
Jeff488's Avatar
Galfer brake lines.
My '08 Wee is getting to the age where it can't hurt to replace the brake lines with stainless steel ones.
I know Spiegler lines are very good and I have them on my other bike, but the Galfers sell for over $30 less.
So. Does anyone have experience with the Galfer brand?
Thanks for your time.
DesertBike likes this.
'08 Silver BMW R1200RT
'08 Weestrom "Screaming Yellow Zonker"
All I want is somewhere to ride and food when I get there.
Looking for Ed Sanders' Truck Stop!
Jeff488 is offline
post #2 of 16 Old 03-18-2019, 06:18 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Yes, we do. Never had a problem with them. Not one.
https://www.adventuretech.biz/braide...ake-lines.html
Big B likes this.
richlandrick is online now
post #3 of 16 Old 03-18-2019, 08:18 PM
blaustrom's Avatar
What makes you think that 10 years is the max for your brake line life expectancy? Are they cracked or otherwise showing signs of decay?
Big B likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 16 Old 03-21-2019, 06:37 PM
Change them out, if for no other reason than they will greatly increase your brake lever feel in threshold braking.
I did my '09 about 3 years ago--no, the OEM lines weren't cracked yet--and it made a huge difference.
I installed new HH sintered brake pads at the same time and they give more initial bite than the organics, albeit a little harder on the rotors.
badjuju is offline
post #5 of 16 Old 03-26-2019, 10:05 PM Thread Starter
Jeff488's Avatar
I've had an experience with a collapsed rubber line on a vehicle about 15 years old. It was not a pleasant day.
Besides, i want to fiddle with my bike.
Jeff488 is offline
post #6 of 16 Old 03-27-2019, 01:07 AM
Hank122's Avatar
I bought the slightly longer Galfer lines a couple years back because I was adding bar risers. They worked well and were an improvement over stock.
Changing the front lines makes for a somewhat tedious bleeding process. Takes a little longer is all.
Henry
"Rock bottom will teach you lessons that mountain tops never will..."
2016 V-Strom DL650 (red) 'Sweetness'
2011 V-Strom DL650 (white)
Hank122 is offline
post #7 of 16 Old 03-27-2019, 01:29 AM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
I have Galfers and think they are an improvement. They don't turn the brakes into Brembos.
But slightly better than stock.
However, on installation I lost an olive crush washer and the bike sat for 10 days waiting for a spare. If you go for it PLEASE ask for an additional spare olive washer on your initial order. You won't find one anywhere else in the universe so get a spare in the beginning. Just in case.
On the improvement level, I think a complete refit is the way to go. Our calipers are very weak and you can't get around that unless you replace them with big pots.
This is the most glaring weakness of our bikes IMO.
Big B and DesertBike like this.
Coach23101 is offline
post #8 of 16 Old 03-27-2019, 03:36 AM
branthopolis's Avatar
Your reply strikes me as a bit odd... Are you actually suggesting that a person should wait until they notice cracking or dryrotting on their brake lines before replacing them? Suzuki recommends replacing brakes lines every 4 years... OP is at 2 1/2 times that interval.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #9 of 16 Old 03-27-2019, 12:46 PM
Onboard Mass Damper
DesertBike's Avatar
4 years is way too cautious IMO. My stock lines looked great after 12 years of service. However, I did feel I was pushing my luck. Some of the other rubber bits (mainly cooling system hoses) had lost their elasticity and I'd already had to replace them to stop leaks.
I was due for new brake fluid this spring, so, why not get new lines at the same time? I also wanted to add taller handlebar risers (Rox 3.5" specifically), so needed extended lines, as well as new ones.
I got the Galfer +2" lines from Adventuretech, and installed them a few weeks ago. They've been great.
I'm skeptical that the "improved brake feel" is anything but placebo effect, but I definitely have nice brake response.
2007 Vee
DesertBike is online now
post #10 of 16 Old 03-27-2019, 01:29 PM
I agree that the maintenance schedule is very cautious, but to imply that someone should ignore the manufacturer recommendation by more than 2.5x because there may not be visible signs of rot/crack. Brakes are pretty darned important... The majority of riders are hard pressed to keep proper air in their tires, much less full inspection of the entire length of their brake hoses and associated fittings on a regular schedule.
~Mark
2015 DL1000A
2005 YZ250
SV Racing Parts, Galfer Black SS Brake Line Kits and Galfer Brake Pads SV Racing Parts SV Racing Parts 127 09-20-2017 03:52 PM
Installed New Galfer Brake Lines Today LocomotionCruiser DL650A - 2012-2016 5 10-04-2015 10:12 PM
Lowest Prices, Galfer Brake Pads Super Sale and Free Bonus Gifts!! SV Racing Parts SV Racing Parts 5 03-08-2015 03:24 PM
