Help - mystery part after valve adjustment - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 2 Post By Yarz1
  • 2 Post By DC_Dave
post #1 of 7 Old 03-17-2019, 04:45 PM Thread Starter
DC_Dave's Avatar
thanks for opening this. Hopefully someone will be able to help me with this.
I took the bike part 2 adjust the valves for ski season, and then didn't have any weekends to finish it up until this weekend.
As a result, I have one part leftover!
Does anyone recognize it and can they tell me where it goes?
I took everything off, including the radiator, required to do the valve adjustment. I tore into the brakes, front brakes, a little bit. As well as the left handlebar protector.
Thanks in advance!
Dave
DC_Dave is offline
post #2 of 7 Old 03-17-2019, 04:47 PM Thread Starter
DC_Dave's Avatar
File Type: jpg IMG_20190317_153344429_1552852117061.jpg (231.8 KB, 18 views)
'07 DL650A - crash bars, skid plate, centerstand, calsci screen, madstad, bestem 2012 trunk, fenda-extenda, handguards, heated grips, grip puppies
The bikes I sold to buy the V-Strom: Husky SM610, Kawi ZRX1200R
**advertising removed by admin - DO NOT REPEAT**
DC_Dave is offline
post #3 of 7 Old 03-17-2019, 05:17 PM
that looks like it might be the spacer used on the bolt, on the upper left side of the radiator. The holder on the radiator has a rubber bushing into which the bolt slides through and threads into the frame. That looks like the spacer that goes on the bolt before shoving it into the rubber mount.
specifically part #4 at https://www.ronayers.com/oemparts/a/...563a8/radiator
Gert and Warhead like this.
Yarz1 is offline
post #4 of 7 Old 03-17-2019, 05:29 PM
Warhead's Avatar
My thoughts are the same on this matter
Don't drop your bike after owning it for 3 hours.
Warhead is offline
post #5 of 7 Old 03-17-2019, 07:52 PM Thread Starter
DC_Dave's Avatar
Good thoughts!
Turns out, it's the left handguard/clutch bolt spacer.
Phew!
DC_Dave is offline
post #6 of 7 Old 03-18-2019, 02:38 PM
Justin35's Avatar
How many miles are on your bike? Does the bike sound any different after the valve adjustment?
Justin35 is offline
post #7 of 7 Old 03-18-2019, 04:22 PM Thread Starter
DC_Dave's Avatar
The valves were done @ 30.5k miles on the clock - this was the first check, and all the valves were within spec, but the left front exhaust was .03 within range.
It doesn't seem to sound any different- but it does seem to run better (I think this is in my imagination). Note - increased valve clearance means more aggressive valve opening - essentially, the bucket is on a steeper part of the cam when opening begins. It might actually make more torque with more clearance.
The valve adjustment took a LOT longer than I thought it was going to. I set the clearance on all the cylinders to the maximum and don't plan to ever check them again.
DC_Dave is offline
difficulty level of valve adjustment? domromer DL1000 from 2002-2012 10 07-23-2014 02:24 PM
It was my first valve adjustment on a Strom biggyfries V-Strom Service and Maintenance Questions and Discussions 10 08-21-2012 02:12 PM
Valve adjustment was going great...until I stripped bolt on the rear valve cover AreyH DL1000 from 2002-2012 6 05-19-2012 08:15 AM
Valve Adjustment Price Born to Run Maintenance, Tech and Products. 4 02-02-2011 12:32 AM
Wee-strom valve adjustment... Toad Rider General V-Strom Discussion 1 11-30-2007 03:19 PM
