Could you listen and tell me if this engine sounds right to you? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 37Likes
post #1 of 30 Old 03-12-2019, 08:13 PM Thread Starter
Justin35's Avatar
2004 Vstrom 650, 26,xxx miles. Sunday had the oil changed to Amsoil 10 w40 w/Wix filter. I've owned this bike for about 2000 miles. I'm the 3rd owner and the 2nd owner reported he did not have the valves adjusted. I'm thinking its time. It has been making some noise and I think its top end noise, like a valve adjustment is needed. I'm concerned its a different issue from the valves but I hope not.
Its a little annoying while riding because I can kinda hear it but when the helmet is off, like when I just ride in the driveway to put it in the garage, it downright scary sounding in person.
Please just give this a listen and tell me what you think.
Thanks!
Justin
It was about 40 degrees outside, thus the steam. Not smoke!
gwc likes this.
Justin35 is offline
post #2 of 30 Old 03-12-2019, 09:01 PM
blaustrom's Avatar
Other than that it has a Holeshot can and is exceptionally clean I can't find anything else to comment on.
How on earth can you hear if the valves need adjusting?? The only way to know is to measure the clearance and if it has never been done, do it!
Other than that, get some earplugs and make it dirty ;-)
gwc, notacop, K9 Wee and 3 others like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 30 Old 03-12-2019, 09:16 PM
Motor7's Avatar
Sounds like a normal strom to me..........
madstrom, Spec, marcham and 1 others like this.
15 DL650XT
Motor7 is offline
post #4 of 30 Old 03-12-2019, 09:24 PM
K9 Wee's Avatar
Yeh, the Stroms sound like a washing machine full of marbles or a sewing machine on steroids. Sounds good to me, but agree with Blaustrom that the only way to know the state of the valve clearances is to check them or have them checked. At 26k it is overdue but it sure would not be the first Strom to experience that.
madstrom likes this.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #5 of 30 Old 03-12-2019, 09:51 PM Thread Starter
Justin35's Avatar
LOL Thanks for the reply. Holeshot? It is a StainTune that came with it when I purchased it. It had a baffle, but I misplaced it. I like the sound.
So wow, hard to believe of the consensus so far that it sounds close to this even when healthy. Box of rocks indeed. Seems to run fine though. I'll keep watching for other replies but I thinkn I'll have my mechanic check the valves if for nothing else my own peace of mind.
EDIT: Also, while I have your attention, should the sightglass have no oil in it while the engine is running? I tried to fill it as close to the fill line as possible Sunday when I changed the oil. I realize some goes in the oil filter, bringing the level down.
Justin35 is offline
post #6 of 30 Old 03-12-2019, 09:59 PM
Spec's Avatar
1st bike?
Sounds normal to me. Motorcycle engines are noisy, you're sitting right on top of it after all.
I always ride with ear plugs. On the rare occasion that I don't I can't stand the engine mechanical noise. I know that it's normal but it's distracting!
You won't see oil in the sight glass with the motor running. You also won't see the oil on the sidestand with the motor off.
The bike has to be level and the motor needs to be off for a few minutes to get an accurate level in the sight glass.
Big B, madstrom, K9 Wee and 1 others like this.
Spec is online now
post #7 of 30 Old 03-12-2019, 10:02 PM Thread Starter
Justin35's Avatar
Originally Posted by Spec View Post
1st bike?
You're nearly right. It's my 2nd. I bought a little Honda NX250 (rare bike) to learn on. Rode for about 1 year then upgraded to this. I'm fairly particular and careful about my motorized possessions. I want them to be in perfect shape.
Justin35 is offline
post #8 of 30 Old 03-12-2019, 10:18 PM
My 04 Wee with 99.5K miles sounds like that but I wear ear plugs and don't worry about it.
Every 15 years you may want to check the valves.
Big B, Spec and VSrider like this.
post #9 of 30 Old 03-12-2019, 10:36 PM
Motorpsychology's Avatar
Ok, everyone else says it sounds normal. Maybe because you were holding your phone close to the crankcase, but to me it sounded like a worn/loose primary chain. With the phone nearer the head(s) it sounded like an arcing spark plug wire, but I would have expected a rougher idle. So chalk it up to greatly amplified and localized normal sound, and enjoy your bike.
"I never said half of that stuff."-Confucius
Motorpsychology is offline
post #10 of 30 Old 03-12-2019, 10:38 PM
VSrider's Avatar
Did you notice an increase in noise after the oil change?
VSrider is offline
