Turn Signal cutout by PO? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 18 Old 03-06-2019, 08:57 PM Thread Starter
Hello all,
I've recently wanted to update my front turn signals but have found that the previous owner has had fun dropping this bike onto the bits that stick out (i.e. turn signals and plastics). They replaced the front signals with a semi flush mount type signal that I think don't stick out quite enough for other drivers to see which makes daily riding scary at best.
I ordered some LED signals and when I went to pull off the old semi flush ones I noticed what looks like a massive cutout where the original used to be. Is this normal? I'll post a photo later but its on my phone right now. I'm wondering if its almost the same size as the OEM signal and if I'd be able to put some back on or if I'm looking at a new headlight fairing?
Thoughts?
2005 V-Strom DL650
Bearded Viking is offline
post #2 of 18 Old 03-06-2019, 08:59 PM Thread Starter
Here’s the cutout with the semi flush signal
File Type: jpg B0735970-749B-417B-AC6B-40B00D4F9508_1551920329868.jpg (238.2 KB, 10 views)
2005 V-Strom DL650
post #3 of 18 Old 03-06-2019, 10:11 PM
Get some thin metal and make some backing plates. My salvage has little tiny flush mounts so the holes can't be too big, haven't looked.
Or, order up some replacement plastic panels.
Gert likes this.
post #4 of 18 Old 03-07-2019, 03:10 AM
Gert's Avatar
If you do decide to find standard indicator replacements from a scrap yard, e-bay, dealer, etc, you may want to consider shortening the indicator stalks. Many pix on how to do this mod, Alain27 - Raccourcir les clignotants avant pour qu'ils ne touchent pas en cas de chute, without having to use the Google translation.
Gert is offline
post #5 of 18 Old 03-07-2019, 04:23 AM
Rolex's Avatar
I used the black plastic from a old oil bottle to make spacers and fill the gaps.
By using plastic if you dump the bike in the future the indicators will pull free more easily without any further damage and will go back in place just as easily.
Brockie likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 18 Old 03-07-2019, 05:08 AM
Leon's Avatar
Seconding that idea.
I've done a very similar thing another bike and found that it worked very well. I had to use a little bathroom silicon sealant to help keep it all in place (and keep any water out as part of the loom for the headlight ran right next to, not sure if it was needed but as I'd got it all apart didn't seem to be a bad idea) but it held and didn't move about.
notacop and Bearded Viking like this.
The more you think the less the better.
Notable bikes: SV650S (Sold), Kawasaki ER5 (Being repaired), 01 Blade (Sold), Another SV650S (Sold), 05 GSXR1000 (Sold), Suzuki GSF400Z (Sold), Yamaha FZR400RR Streetfighter (Sold), Kawasaki GPZ500S (Sold), Yamaha XJ600 Divvie (Crashed), 04 Kawasaki ZX10R (Written off at Snetterton), GSX750X (Sold), 04 ZX6R (Sold), 02 ZX6R (Sold), 94 FZR600R (Sold), 91 NC30 (Sold and missed), 87 GSXR750 (Sold and really missed), RD125LC (Crashed, rebuilt then sold).
Leon is offline
post #7 of 18 Old 03-07-2019, 09:43 AM
I got replacement aftermarket turn indicators at the local Power Sports shop for about $20 and the stalks were shorter and more flexible.
They are dual filament so you can have running rights too. I had to use some large washers to fill in the difference in hole size.
post #8 of 18 Old 03-07-2019, 10:28 AM Thread Starter
Originally Posted by Gert View Post
If you do decide to find standard indicator replacements from a scrap yard, e-bay, dealer, etc, you may want to consider shortening the indicator stalks. Many pix on how to do this mod......
Thank you for the link! I'll have to look at doing that so that I don't have future issues haha
That's a fantastic Idea! I was wondering how I'd fill in the gaps rather than buy an almost $300 headlight fairing just for the turn signals to break if I ever dump it again.
I'll have to check with my shop but they charge and arm and a leg because they're the only racket in town but I like the idea of running lights to be more visible!
2005 V-Strom DL650
post #9 of 18 Old 03-07-2019, 08:34 PM
Brockie's Avatar
It is simple enough with a 12v circuit tester.
The three wires will be a 5a or so for the running light, a 21a or so for the indicator, and an earth.
Connect the 21amp and the earth to the two indicator wires. Then find a wire anywhere in there that is powered on with the key and then splice the 5 amp wire to it.
Brockie is offline
post #10 of 18 Old 03-07-2019, 10:52 PM
trapperdog's Avatar
That would be watts, not amps. 😀
Brockie likes this.
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
Tags
dl650 , signal
Converting any 2-Wire turn signal into Running + Turn Signal thepaleobiker General V-Strom Discussion 40 04-26-2018 11:47 PM
Pickled - Turn Signal Wiring Harness johno_SLC V-Strom Service and Maintenance Questions and Discussions 1 01-14-2017 02:07 AM
Turn signal upgrade FredBGG General V-Strom Discussion 7 12-15-2014 02:02 PM
Rear turn signal differences question brokeagain General V-Strom Discussion 3 05-14-2014 03:48 PM
Updated Turn Signal Post 2presidents DL650 and DL650A - 2004 to 2011 8 02-15-2014 10:51 PM
