MPG question... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 02-26-2019, 10:17 AM Thread Starter
MPG question...
So I bought an 07 Wee. Exhaust had been gutted. When I asked about mpg he acknowledged that the gutting of the exhaust really took its toll on the mpg.
I was averaging about 36mpg in town. Put a pretty little Delkevic exhaust on it, which sounds pretty good btw, mpg bumped up 1 or 2 but not much. Will a Fuel commander help?
I had an 09 Vstar 1300 that i put a K&N air filter and slip on exhaust on, dropped 2 mpgs but the power commander brought it back to where it was previously.
post #2 of 4 Old 02-26-2019, 10:42 AM
Just asking, but are you sure this bike has the stock gearing on it?
Look for a oem stock exhaust. The lack of backpressure with what you now have can cause lean running, and a PC will try to add fuel(through increased injection duration), which may drop your gas mileage even lower.
MAZ4ME is offline
post #3 of 4 Old 02-26-2019, 12:02 PM
I have run a "gutted" exhaust on a 2004 DL 650. No change in fuel mileage.
36 mpg in town is EXTREMELY low. I would ask that you be sure your odometer is reading correctly and that you can do a manual mpg check for a couple tankfuls.
Beyond that I wonder if there are other issues with this bike causing ( assuming it is correct ) the low mpg? There is a list of things that can effect that.
realshelby is offline
post #4 of 4 Old 02-26-2019, 12:07 PM
iamsmiling's Avatar
That does seem like very poor mileage. My first Wee had a drilled muffler and I averaged 50 mpg around town and generally under 6,000 RPM.
What is your riding style? Are you super aggressive on the throttle?
iamsmiling is offline
Question from the electrically challenged Wee Willy Winky General V-Strom Discussion 5 01-13-2015 05:21 PM
Tire Question? But not which tire question VStromThom DL1000 from 2002-2012 11 03-23-2014 11:51 AM
wiring a ground question chetc General V-Strom Discussion 7 11-16-2012 06:38 PM
DL1000 Chain Question (ordering question) shawnubis DL1000 from 2002-2012 5 11-16-2012 10:31 AM
Dirt, gravel and mud question TheWall DL650 and DL650A - 2004 to 2011 19 06-02-2012 11:11 AM
