Clutch actuator too much play - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By gwc
post #1 of 8 Old 02-25-2019, 09:10 PM Thread Starter
Hello all, just wanting to know if my clutch actuator on my 2004 Suzuki V Strom 650 has too much play. Please see the Youtube video I took, link is below.
Also, It seems when I ride on hot days and the bike is hot, the free play begins to become more. I know there is no hydraulic clutch fluid because of the cable driven clutch so how could this be? Could that be a sign of a clutch going bad or my clutch adjustment being off?
Thanks a lot.
Matthew Fowler is offline
post #2 of 8 Old 02-25-2019, 09:23 PM Thread Starter
Ok so it won’t let me post a link because I haven’t posted enough threads so i’m not sure if I could message someone personally or gets somones email/phone number. Just let me know
post #3 of 8 Old 02-25-2019, 09:59 PM
Brockie's Avatar
Even without watching the video I am guessing that your clutch is probably in need of adjustment.
This entails both the clutch itself, as well as the cable.
Go through these threads. It is a very simple and painless process.
https://www.stromtrooper.com/dl650-d...ml#post5259037
https://www.stromtrooper.com/v-strom...ment-help.html
Brockie is offline
post #4 of 8 Old 02-25-2019, 10:33 PM
gwc
You can PM me, I have a 2004 DL650 so itíll be an apples to apples comparison.
Brockie likes this.
GWC
2004 DL650
gwc is offline
post #5 of 8 Old 02-25-2019, 11:08 PM
V-Tom's Avatar
When you are working with the actuator (in the housing where the front sprocket lives) check the lever that the lower end of the clutch cable is attched to. On my 2006 the spot weld that held the lever firm broke.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #6 of 8 Old 02-25-2019, 11:54 PM
Sprocket's Avatar
I found your YouTube video. I just searched for "Suzuki V Strom clutch actuator play" and it came right up.
It's normal for there to be some wiggle in the interior part of the clutch actuator. Yours might be a bit looser than typical, but I doubt it's too far gone to get the clutch adjusted properly.
There are two settings involved in adjusting the clutch, and they interact with each other: the slack at the hand lever and the depth of the screw in the center of the actuator.
The gist of the procedure is this:
  1. At the hand lever, adjust the cable to provide lots of slack. Max it out.
  2. At the clutch actuator, first loosen the nut surrounding the screw, then rotate the screw so that it's a quarter turn counterclockwise (loosened) from the position where it was when it stopped as you turned it clockwise. Retighten the nut that surrounds the screw.
  3. Adjust the cable so that when you squeeze the hand lever, there's about a half inch of movement before you feel resistance, that is, before you begin to disengage the clutch. The manual says to adjust the cable at the end near the actuator, but it's not uncommon for there to be inadequate adjustment range available there, so it's necessary to take up the slack at the hand lever.
Blue 2007 DL650
Sprocket is offline
post #7 of 8 Old 02-26-2019, 01:19 AM Thread Starter
Thank you for all of the replies, I have followed the procedure to adjust the clutch but worry that my half inch of play is just the actuator "play" and not actually a half inch of disengagement. I was thinking it might have something to do with why it slackens more on a real hot day. I have adjusted the clutch again and it is feeling good. I appreciate you all looking at the video and just helping to confirm that the actuator looks ok.
post #8 of 8 Old 02-26-2019, 03:49 AM
Gert's Avatar
Gert is offline
Tags
clutch , freeplay , hot
Clutch engagement too CLOSE to grip Nelsonmd DL1000 from 2002-2012 8 09-24-2014 04:15 PM
DL1000 clutch won't release Stobie V-Strom Service and Maintenance Questions and Discussions 14 12-28-2012 05:01 AM
Extended clutch arm? SRTeric DL650 and DL650A - 2004 to 2011 1 09-02-2012 03:47 PM
