List Of Tools - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 16 Old 02-25-2019, 06:58 AM Thread Starter
StromVirgin's Avatar
List Of Tools
Hello Everyone:
As I am new to this bike, is their a common list of tools or spare parts that are normally recommended be carried at all times ?
I did purchase the factory service manual for my new to me 2009 650 with less than 19K.
Thank You
Never Allow The Radical Views Of The Few To Infringe On The Constitutional Rights Of The Many
StromVirgin is offline
post #2 of 16 Old 02-25-2019, 09:44 AM
Motor7's Avatar
That list can vary depending on need and personality. Some guys carry way to many tools for North America, while others just use the oem tool kit provided. I do a little of both, deleting some useless oem tools and adding my own.
-a set of metric allen's
-2 Motion Pro aluminium tire Spoons(spoon on one end, metric box wrench of your choice on the other...one of mine of is for the large rear axle nut)
-a compact metric ratchet set and sockets
-assortment of metric wrenches
-tire plug kit
-small compressor
-small roll ea of Gorilla tape and safety wire
-I always wear on my belt a Leartherman ChargeTTi including two complete bit sets(absolute lifesaver more than once)
Most go in a tool tube mounted behind the oem rack on the left side, the rest under the seat.
15 DL650XT
Motor7 is offline
post #3 of 16 Old 02-25-2019, 11:52 AM
Spec's Avatar
Originally Posted by StromVirgin View Post
Hello Everyone:
Thank You
You want to prepare for the most likely event first, a flat tire. Get a string plug kit and a small compressor that you connect to the battery. You can't use the dash outlet for the compressor it will blow that fuse. Know how to fix the tire, watch vids practice on an old tire if you can.
You don't need or want to remove a wheel to fix a tire. There isn't a need anyway (with tubeless tires) unless you destroyed the sidewall but then you would need a new tire.
Outside of a flat there isn't much need to carry tools really. Unless you are going on long trips and expect to change oil or sumpthin' modern bikes are very reliable, a Strom exceptionally so. The OEM kit has the minimal tools needed to tighten up a mirror or a loose license plate bolt, stuff like that. Throw a few fuses in, some tape, tie wraps, etc. the kind of things to get you back to civilization.
A lot of people will posts lists of extensive tool kits expecting to be prepared for most anything or wanting to help other less prepared riders. Good on them but reality is (in a first world country anyway) you aren't stranded with a broken down bike. Not that it's likely to happen these days.
Spec is online now
post #4 of 16 Old 02-25-2019, 12:05 PM
chicago's Avatar
if you type 'tool kit' in the google custom search box you will see all the past threads/posts re this topic.
14 tooth for me
chicago is offline
post #5 of 16 Old 02-25-2019, 03:05 PM
I agree with Spec. There just isn't much you can do if your bike acts up on the road or trail. Things like axles and bars should not come loose unless you didn't properly tightan them. Engine problems are pretty much unheard of on the road unles it is a major component that you can't repair anyway. Tires are the main concern. I'd agree, a tire repair kit, compressor, some tape in case your backpack strap breaks, maybe a bit of wire for that strange thing you don't expect. A couple of fuses and a flashlight might bei good; cell phone charger.
Spec and Motorpsychology like this.
Wee Willy Winky is offline
post #6 of 16 Old 02-25-2019, 03:20 PM
chicago's Avatar
I agree I would keep it basic for local/Canada/US. I carry a small voltmeter for basic electrical troubleshooting.
notacop likes this.
14 tooth for me
chicago is offline
post #7 of 16 Old 02-25-2019, 03:21 PM
Agree on a tire plugging and reinflation solution.
I wouldn't go on a long tour on a chain drive bike without a tool to loosen the rear axle, to allow for chain adjustments. I don't think there is anything in the tool kit that will actually work.
I don't worry about bringing a bunch of extra tools, beyond that. However, I do pack a few things under the seat:
A roll of electrical tape.
A wad of duct tape (take off roll and re-roll smaller).
A pair of needle-nose pliers (useful for all manner of things).
A length of stainless steel lockwire - can be used in a pinch for many things, plus unlike most tape it will stand up to heat.
And, of course, on a chain drive bike I bring chain lube with me on any tour.
Spec likes this.
V-Strom Ry 2 is offline
post #8 of 16 Old 02-25-2019, 04:11 PM
Motorpsychology's Avatar
TOOL#1: Cell phone & charger. Having tow service on your insurance or AMA membership or other motor clubs will get you to where you can get repairs done, or get the bike back to your home. Most smartphones have a flashlight app.
TOOL#2: The factory tool kit is adequate to fix anything that can be fixed on the road during a commute or errand running; be careful not to hog out Allen heads or round off nuts. If you do, see tool #1.
TOOLS 3 AND UP: a roll of electrical tape to use as duct tape (it packs smaller) for those things that are hanging or broken off. A few zip-ties fit in the factory toolkit as well. The toolkit tools I consider emergency use only. If you are planning to do your own regular maintenance and light repair work, then invest in better tools. And remember, you get what you pay for; I'd stay away from the 101-piece tool set for $19.95 bargains.
FLAT TIRES I personally stay away from products such as Slime, as I've had it seal up the Schraeder valve along with the leak! A tire repair kit is good peace of mind and a $35 electric inflator packs small. Also handy if you've bled out 10-12 lb of air for offroad riding. Also an air gauge; dial type are usually the most accurate
For epic cross country adventures there are many guides and articles online dealing with what to pack for tools and other gear.
"I never said half of that stuff."-Confucius
Motorpsychology is offline
post #9 of 16 Old 02-25-2019, 08:09 PM
Stalky Tracker's Avatar
I am one of the "some guys carry way to many tools for North America" guys Motor7 is referring to.
I carry a small air compressor (Slime) and jumper cables under the seat. The string or rope tire plug kit in the left side case. Spare fuses, tire gauge, small metric hex key set, and electrical tape are in the tank bag. And of course, a credit card and cell phone. These are always with me.
In my tool pouches, which I carry on extended trips and over-nighters in the side cases, are:
pliers
pliers - needle nose
wire cutters
tire irons w/22mm wrench
tire irons w/24mm wrench
3/8" socket ratchet
3/8" breaker bar
3/8" extension - 10"
3/8" extension - 6"
3/8" extension - 3"
3/8" extension - 1.5"
JIS screwdriver - No. 1
JIS screwdriver - No. 2
JIS screwdriver - No. 0
JIS screwdriver - No. 00
screwdriver - flat 1/4"
screwdriver - flat 1/8"
screwdriver - Torx 25
screwdriver - Phillips #1
17mm combination wrench
14mm combination wrench
13mm combination wrench
12mm combination wrench
11mm combination wrench
10mm combination wrench
8mm combination wrench
5/8" spark plug socket - 3/8" drive
flex joint - 3/8" drive
12mm hex socket - 3/8" drive
10mm hex socket - 3/8" drive
8mm hex socket - 3/8" drive
6mm hex socket - 3/8" drive
5mm hex socket - 3/8" drive
4mm hex socket - 3/8" drive
24mm socket - 1/2" drive
1/2" to 3/8" drive adapter
22mm socket - 3/8" drive
17mm socket - 3/8" drive
14mm socket - 3/8" drive
13mm socket - 3/8" drive
12mm socket - 3/8" drive
10mm socket - 3/8" drive
6mm socket - 3/8" drive
electical tape
12" cheater bar
However, in all my travels since 2006, which included twelve extended trips (ranging from 3600 to 4900 miles each over two-four weeks), I have only used electrical tape and four tools: pliers, 10mm combo, 8mm combo, and a 2.5mm hex key. The pliers and 10mm to tight up the shift linkage adjuster that came loose and the 8mm to tighten the right mirror bolts. Electrical tape to fix a turn signal when I got too close to a bridge's frame work and another time when I got too close to the ground. And the 2.5mm hex key to tighten up a MRA X-Creen spoiler that loosened up on some rough roads looking for the Revenant.
Ya, I know. I have been meaning to pare that down but, well, just haven't gotten around to it. Easier to carry, then you know it's there.
Hopefully, the good fortune will continue.
Spec, STCorndog and kingjahrome like this.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #10 of 16 Old 02-25-2019, 11:15 PM
Most of the tools I carry have been of some help to others. The Wee has been faultless. I got a slime pump and took it it out of its case and carry it under the seat.
Don't bother with tools that you don't know how to use. The tools I carry are mostly wrenches I inherited, Stahlwille. Thin, lightweight and accurate. And they are close to 50 years old now.
The sockets are Sears stuff. You can find odd ball sets occasionally the are quite functional. I carry a length of copper tube for added torque when tightening on a 3/8th ratchet.
The worm plugs are nice and work but get new set occasionally cus they dry up. They all fit in a bag in my 4" tool tube nicely with a length of tubing for syphoning gas in emergency. The factory set languishes under seat tool. I have a set of Allen wrenches i won in the top box.
Alaska packing list AR-Stromer General V-Strom Discussion 47 06-25-2014 10:51 AM
AssistanceList.com, a global network of help on or off the road. assistancelist Travel Registry 2 03-14-2013 04:57 PM
