New LED headlights + EB relay = High Beams Only? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 01-20-2019, 09:32 PM Thread Starter
Looking for help doing some troubleshooting.
Just installed a new set of Beamtech LED headlights. I'd previously had the Eastern Beaver relay installed too.
The issue: with both LED bulbs installed I only get High beams no matter what position the switch is in.
With only one LED installed the switch/bulbs work just fine.
Thoughts?
Chefdave is offline
post #2 of 7 Old 01-20-2019, 09:37 PM
I'd say you goofed something. I installed the EB cabling and later added LED's and no problem with the end result. Low and high beam work as designed.
notacop is online now
post #3 of 7 Old 01-20-2019, 09:45 PM Thread Starter
Bulbs have both high and low LED's.
You can switch between high/low just fine with only 1 bulb installed.
Chefdave is offline
post #4 of 7 Old 01-20-2019, 10:14 PM
Warhead's Avatar
Have you tried one LED at a time in both position (left then right)
Don't drop your bike after owning it for 3 hours.
Warhead is offline
post #5 of 7 Old 01-20-2019, 10:52 PM
Brockie's Avatar
I am assuming that you have a Wee1 or Wee2 and guessing that your wiring from the EB relay is wrong.
You could confirm this by reverting to OEM headlight wiring. I have LED's in my Wee1 with no relay. Simple plug'n'play.
Brockie is offline
post #6 of 7 Old 01-22-2019, 06:11 PM
Rolex's Avatar
LED's are polarity sensitive unlike normal globes, so + must run to + and - to -.
Do you get the same result with one incandescent globe and one LED ?
Use a meter and probe the back of the globes to ensure the current is flowing in the right direction when the switch is being manipulated.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 7 Old 04-16-2019, 05:34 PM
Also interested to hear about this. I have the EB with single relay cutout and thinking about a headlight upgrade
2009 Wee-Strom. Center Stand, Givi crash bars, AMS skid plate, MadStad wind screen mount, Cee Baily Windscreen, voltmeter, fork mount fog lights, Shinko 804/805, seat concepts saddle, EB PC8,heated grips, single headlight cutout, dual USB charger, 12v charger. Next mods: sonic springs, short blinkers, bark busters, delkevic exhaust.
StromRider30 is offline
Flash to Pass & Headlight Relay Kit gdrew DL650 and DL650A - 2004 to 2011 24 04-04-2018 11:58 AM
Yelled at for high beams, but they weren't on SteveFoy DL650A - 2012-2016 20 06-14-2017 12:15 PM
High beams and the blue indicator light Aka DL650A - 2012-2016 21 07-09-2013 04:28 PM
Electronic Help - burnt wire! EB headlight relay and EB fuse box Photoryder Maintenance, Tech and Products. 18 04-23-2013 08:34 PM
high beams not working dphares DL1000 from 2002-2012 8 04-01-2013 08:27 PM
