is dual pipes possible? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 01-11-2019, 03:30 PM Thread Starter
One more question for those of you out there, im doing some heavy mods on my wee because i've been riding it for a decade now and grown just a little bored (love the bike still) but can't afford another bike at this time. I've always loved either an under tail or dual pipes on bikes for the obvious symmetry, after putting a delkevic system on my bike last summer it seems like it needs a power commander or similar tuner anyways because it's running noticeably rich. question is with tuner anyways would it be possible to dual pipes a 650? and then tune it, because, i know they likely problem is to low pressure at the muffler, or furthermore if i were to constrictor down the pipe diameter would that mitigate that pressure problem?
Granvillan is offline
post #2 of 11 Old 01-11-2019, 04:09 PM
Yes, dual pipes can be done. Already done. And don't be so sure you have to tune the engine. Unless you go with a full race setup including head, mid, and muffler pipes you probably won't be changing the tuning much.
It is going to require some fabrication. I would check on SVrider.com to see if there are some SV650 guys there that have some information that would help. I would say more of them have done it than DL owners.
Big B and Hatchi like this.
realshelby is offline
post #3 of 11 Old 01-11-2019, 06:11 PM
OydnaR's Avatar
I'll give you my original dual pipes free if ya want to come pick em up, also give you a referral to the local fabricator that made my 2 into 1 pipe
IBA#9560
Copyright (c) 2019
OydnaR is online now
post #4 of 11 Old 01-11-2019, 07:22 PM Thread Starter
did your bike feel any different when going down the the single pipe? is it the same diameter of exhaust pipe now because i would assume you have quite a bit more back pressure not?
post #5 of 11 Old 01-11-2019, 08:28 PM
branthopolis's Avatar
TiForce USED TO do a dual can full system for the SV650, but not aware of anything currently in production or specifically for the DL650... Realistically, any muffler shop that does custom systems can probably fab something up for you...
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #6 of 11 Old 01-11-2019, 08:48 PM
MattR302's Avatar
FYI, the 6th gen VFR800 came stock with a dual undertail exhaust. There was one company (2 bros?) that made an aftermarket exhaust that only used one muffler, the left side was just there for appearance, it wasn’t even connected.
I saw pics from another guy made a “dual exhaust” for his DR650 - except the left side was actually just a muffler shell for a tool tube inside.
Just a couple ideas if you’re going for the looks/symmetry thing.
MattR302 is offline
post #7 of 11 Old 01-11-2019, 09:09 PM
I feel like I have seen a few of the tubes done for the DL650, around on here. Usually with PVC tubing on the off-exhaust side, perhaps under the pannier racks. Looked like they might be pretty decent for things like tools. Can't remember any specifics about any of the threads, but you should be able to find them with a bit of searching.
rambaldi is offline
post #8 of 11 Old 01-12-2019, 08:43 AM
There really isn't much back pressure with the stock system. Not saying there isn't a way to gain power, but the biggest power gains are when you install a full system from the exhaust port back. Just replacing the mufflers to an aftermarket "high flow" type won't net much power gain. Weight loss is probably a bigger benefit. Making it into a two outlet system will add weight.
But it does look good!
If I were going to do this to a first gen DL 650 I would get a couple DL 1000 mufflers. Either stock or aftermarket. Get the hardware to mount them like the factory did on the 1000. Then figure out where/how you want the connector pipe to run. Get one bent at a muffler shop. Cut into the side of the mid pipe and weld in the new pipe. Then make it fit the DL 1000 muffler.
post #9 of 11 Old 01-12-2019, 10:30 AM
PerazziMx14's Avatar
Other than looks and sound I doubt there is much positive power gain on your monetary investment. You will also be adding weight.
As for under tail I like the looks of under tail exhaust but after having a Ducati 848 with dual under tail Termignoni after about 30 minutes you a$$ was roasting. Form not on I'll continue to like the look but opt for conventional positioning.
PerazziMx14 is offline
post #10 of 11 Old 01-12-2019, 11:42 AM
OydnaR's Avatar
yep, got ride of the 3k rpm lean spot without remapping
feels a lot faster, but because of the loud exhaust I now have ($27 Thrush Cherry Bomb), I did have to add an 8" insert to quiet it to NH legal limits 92db @ idle,
IBA#9560
Copyright (c) 2019
Protecting Pipes, Luggage "stays" Thumpy1 DL1000 from 2002-2012 7 01-02-2019 06:02 PM
Back to stock pipes HappyWanderer DL1000 from 2002-2012 23 08-06-2015 01:17 PM
