light stays on trouble - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 20 Old 01-09-2019, 11:27 PM Thread Starter
hey guys, i'm new here and in the vstorm world (motorcycle world to be true got my license by the end of the summer)
last time i've used my vtrom (2009 dl650A) the light on the bike all stays on both low beam and rear marker lamp, event with the key off and out of the ignition switch, never turn off until i've restart the bike and stoped it again, the next day when i've get to start it battery was completely dead (new one from about a month before) i've charged the battery and every thing was good
the bike is now stored for winter but when i've parked it in the garage the same problem happen again until i've unpluged the battery
do anyone have a clue where i can start my start research to repair this problem ?
thanks for the help
ps. sorry if my english is not right i'm from quebec and don't practice it enough hope you can understand most of it haha
HisPhil75 is offline
post #2 of 20 Old 01-09-2019, 11:51 PM
blaustrom's Avatar
First of all welcome to the forum. Once you have fixed your bike you will find a lot of good and useful info here.
Check out NEVA19 when it comes out. It's our NE meet typically first weekend in August. This year likely in NH, 2018 was in Ontario. Maybe next year in Quebec?
Now to your problem, I have no definite answer, others will hopefully chime in with more direct experience or memory where to look. Do a google search for headlight staying on on stromtrooper.com
https://www.google.com/search?client...n+stromtrooper
There are many instances where they don't come on, need to check the starter switch. NOTE: On the 2005 and newer bike the headlights are being routed through that switch in order to turn them off while cranking. Too much load on that switch and they frequently burn up. Instructions here: https://blacklabadventures.com/2012/...h-maintenance/
If not installed on your bike I recommend to install a headlight relay set from Eastern Beaver https://easternbeaver.com/Main/main.html
If I remember right there have been reports about the ignition switch acting up. I would investigate that possibility after checking the starter switch.
Whilst you are fixing the electrical system add a digital V-meter (a cheap one from e-bay is just fine) to the setup to be able to monitor the health of the charging system, another known potential trouble component. In case the alternator is on it's way out, it gives you some prior warning and hopefully will prevent you from getting stranded in the middle of the James Bay road ;-)
Gert likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #3 of 20 Old 01-10-2019, 12:01 AM Thread Starter
thank for that bud ! first time i heard from the V-METER but i will definitly look up for that !! i am looking to get my passport to do some ride your side of the border ! i'm living about 15 minutes from the border so i'll probably get to make some ride in the great america !
post #4 of 20 Old 01-10-2019, 12:07 AM
blaustrom's Avatar
Great then you should definitely look into this event:
https://www.stromtrooper.com/events/...ow-2019-a.html
Blau2 2014 DL1000A
post #5 of 20 Old 01-10-2019, 06:50 AM
Rolex's Avatar
Are you turning the key too far and turning on the park lights ?
Try turning the key fully to the left then turn it one click back to the right before removing the key.
V-Tom likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 20 Old 01-10-2019, 08:45 AM
That is just a parking light, OP says the low beams are on too.
Sounds like a relay sticking....
realshelby is offline
post #7 of 20 Old 01-10-2019, 07:09 PM
Rolex's Avatar
Because he is new I though he maybe confusing the parking light and the low beam globe ??
V-Tom likes this.
2014 V2, Snoopy
Rolex is offline
post #8 of 20 Old 01-10-2019, 11:11 PM Thread Starter
no the key was at OFF position and even out of the switch
post #9 of 20 Old 01-11-2019, 04:03 AM
Grimmer's Avatar
I haven't had this problem personally, but have read several other posters found that water got into the ignition switch (for some it was a connector). Many of them related the issue as occurring after having washed the bike.
Any recent maintenance, wash, or rain exposure?
Grimmer is offline
post #10 of 20 Old 01-11-2019, 11:32 AM
Warhead's Avatar
Fair question, I did the same thing during the day when I first got my bike. (killed the battery) The "LOCK" position and "PARK" position were too close for me me tell.
After you unplugged the battery to turn the lights off, if you reconnect the battery do the lights come back on?
Don't drop your bike after owning it for 3 hours.
Warhead is offline
Ravetech LED Tail Light JoshM DL650A - 2012-2016 52 10-14-2016 06:09 PM
LED Tail Light (No eBay links allowed) garandman V-Strom Modifications and Performance 47 06-12-2013 11:49 PM
Oil Light OydnaR General V-Strom Discussion 17 04-07-2011 02:12 PM
