No neutral light... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By MAZ4ME
  • 1 Post By Sprocket
post #1 of 5 Old 12-22-2018, 04:12 AM Thread Starter
yourmatejay's Avatar
No neutral light...
So I finally had enough of not having a neutral light and started to look for a cause. Pulled the dash thinking it might be a blown bulb and found they run leds
Checked the connection for the gear position indicator and that seemed fine, no frayed or burnt wires
Pulled the sprocket cover off and pulled out the gear position indicator. Gave it and the pin a clean, out it back together and still no green neutral light. I’m a bit stumped now. Is there any way to test the gps?
覧覧覧覧覧覧覧覧覧覧
Jay
K6 650
yourmatejay is offline
post #2 of 5 Old 12-22-2018, 11:15 AM
It may not be the GPS, you'll have to diagnose this. A wiring schematic(shop manual), a 12V test light, and an inexpensive volt/ohmmeter is all you need.
I realize my bike is a different year/model Vstrom than yours, but just as an example: Power runs from my battery -->Main fuse-->Signal fuse-->Neutral Indicator LED-->GPS neutral contact--GPS ground.
1st thing I'd do is check all the fuses with a 12VDC test light. As you have no other issues in your post, you can eliminate the main fuse((it's in the starter relay) as a problem. At the GPS one wire terminal will have voltage coming FROM your neutral LED with the key in the on position. If no voltage is present you could have a blown signal fuse, open LED, or wiring issue. If voltage is present everything on the supply side of the switch can be eliminated as a cause. Another GPS wire terminal will be ground. If you place your test lamp between the GPS powered terminal and the ground terminal, key on, the test lamp should light. If not, suspect a GPS ground circuit problem. To test the GPS neutral contact, place one ohmmeter lead on the GPS signal wire terminal, the other on the GPS ground terminal, and s
Simply, you have power to the Neutral LED, then to the GPS looking for ground, which is only available in the GPS neutral position. Your specific wiring diagram may be different, but that's the gist of it. Good luck.
Dashing likes this.
MAZ4ME is offline
post #3 of 5 Old 12-23-2018, 04:09 AM Thread Starter
Thanks mate I値l give it a go!
覧覧覧覧覧覧覧覧覧覧
Jay
K6 650
post #4 of 5 Old 12-26-2018, 12:17 AM
Sprocket's Avatar
At the gauges, the wire that provides voltage to the neutral light also provides voltage to the speedo/tach backlighting. So, if the backlighting of your gauges is working, you can be pretty confident the problem is either with the neutral light LED itself or the ground (earth) side of the neutral light circuit.
Here's a way to verify that the neutral indicator light is not burned out. At the big connector on the left side of the bike near the front of the fuel tank cowl (it's in a black rubber boot), locate the blue/black-stripe wire, and with ignition switch on, short that wire to ground (bare metal on the frame). That completes the circuit to the neutral indicator light, so it should light up. Don't decouple the connector; come in from the back side of it with a needle probe. If this test lights the neutral indicator LED, the problem is probably in the ground path.
The ground path for the neutral light circuit passes through a diode in the turn signal/side stand relay (adjacent to the fuse box) before it gets to the GPS. If you can verify continuity through the gear position switch between the blue wire and the black/white wire with the transmission in neutral, I would suspect a faulty diode in the relay. Or, it could be as simple as a corroded contact between the relay and its socket. Be sure the ignition switch is off before you decouple the connector to the gear position switch or remove the relay.
Good luck.
Dashing likes this.
Blue 2007 DL650
Sprocket is offline
post #5 of 5 Old 12-26-2018, 08:58 AM
Just because its an LED doenst mean it cant go bad!
Dockstrom is offline
Neutral light blinking while driving Gianfranco75 DL650A - 2012-2016 17 07-03-2016 08:04 PM
AdMore Lighting's SM Light Bar Joe Shablotnik General V-Strom Discussion 0 06-30-2016 12:49 PM
LED Tail Light (No eBay links allowed) garandman V-Strom Modifications and Performance 47 06-12-2013 11:49 PM
Auxilary light connection Pascah DL650A - 2012-2016 6 02-21-2013 02:27 AM
