Hi,
I have a V-Strom K8, always owned by me that it is since temperatures fall down that has some problem to start, but not always. The sound is the typical one of an exhausted battery however if I detach the battery and test it, I did it twice in two occasions the bike would not start, it seems to be pretty good: 12,4V the first time and 13,3V the second time I tested it. Then I charged it and the voltage arrive at 14,2V. Battery attached and the bike started like a charm, all the two times.
The battery is a Motobatt Mbtx12U and is only one year and half old. I use copper paste on the plugs so the conduction is perfect. Oil and oil filter are new and clean.
Before this battery I had the original Suziky for 8 years and I never had problems even if I let the bike stopped for the whole winter with battery plugged in. Then it started immediately after winter.
How could be the problem? Could it be that even if I have 12V the battery cannot bring enough power the the engine to start?
Thanks for any help.
Have fun...while driving safe!
Sponsored Links | |||
An update: this second time the moto starts with the battery at 14,02V, it however had some problems to start, it takes few seconds to do it.
Could there be engine spark plugs?`They have 7 years and about 8000 km..
Look first at the terminal where the earth wire bolts to the motor, and then the starter motor terminals and solenoid. You have the necessary voltage and yet the motor is a reluctant starter. Look first for poor electrical connections.
First, a battery at 12.4 volts after sitting is on the low side. 13.3 volts shouldn't happen unless it was just on the charger! It takes some time for the flash charge to come off a battery when disconnected from a charger. Couple hours at least for accurate measurement.
Two things come to mind. First is that the battery is bad. How old it is means nothing. If it is not holding a charge, that tells you it needs load tested at least.
On the other hand, if the battery isn't being charged properly, it cannot keep enough power in it to start the bike. If a 650 I would wonder about the stator, if a 1000 I would suspect the magnets in the rotor have moved together. Which can be hard on the stator also.
What is needed is a voltmeter on the bike while running. You want to see 13.8-14.4 volts when above say 3000 rpm. If you are seeing in the 12 volts range or less, the charging system isn't working properly and no battery will work until that is fixed.
Have questions about the clutch in your DL or SV 1000? E-mail Terry [email protected]
Originally Posted by Draako
View Post
Hi,
Load testing keeps getting suggested when a battery thread comes up.
No need to pull the battery out of the bike. Leave the meter on the battery and hit the starter. If it drops significantly and the bike doesn't start, probably you have a bad battery.
Or with the key off the reading is 12+ volts, what does it read when you turn the key to on and the headlights come on?
Load is a load. Just mind the readings on the meter.
The load test the auto parts store or shop use is a big resistor.
Then there are you tube vids on how to clean a battery and get some more life out of it. But you'd be on borrowed time then.
Originally Posted by notacop
View Post
Checking voltage drop with just the headlight and ignition load is good to do, when the bike is starting normally and you have a DMM (or other voltmeter.) Then you are poised to objectively determine whether battery or connection resistance has increased badly. There are some confounding factors to beware of: When the battery is fully charged, and especially if it has been left on a charger, the voltage can drop hundreds of mV just because, during overcharge, a different reaction is occurring than the one which provides the greatest portion of the discharge energy. The drop to attend carefully is the one which starts in the 12.6 to 13.2 V (or thereabouts) plateau part of the battery's discharge curve. This can be tricky to interpret because the drop is many times smaller than what occurs when cranking current is drawn from the battery. When load testing with your headlights and ignition as load gives ambiguous results, a load test with a known, high current load will distinguish starting failure due to an overly resistive battery from one due to a starter motor gone bad due to a shorted winding. That said, I would view the load test at a shop as a late step in the troubleshooting process.
View Post
"If the battery's internal resistance has gone up too far,"
I think the sulfites have built up on the bottom of the plates and the alleged cleaning and wrincing washes it away. Still seems like an effort in futility.
But like mounting a tire igniting hair spray it's kinda interesting.
View Post
Since the battery had been sitting for several seasons it was only reading about 8.5 volts when I removed it from the wheeler and attached the PulseTech Charger/Maintainer. 8.5 volts is WAY below the minimum 10V of a discharged battery and I was concerned the PulseTech would consider it a bad battery and give up. However, it kept pounding away and gaining ground and after a couple of days it read "100%". I wasn't sure if it was completely done de-sulfating, so I called PulseTech. They recommended leaving it attached to the Charger/Maintainer for about a week. I think I actually left it for 3 or 4 weeks. Afterward, the resting voltage was right around 13V. I tested the resting voltage again after 2 months sitting on the bench and it was still above 12.8V. I put it back in the 4 wheeler and it starts right up, and has not had the power steering fault ever since.
I actually use two of these Charger/Maintainers now so I can rotate them between the 4-wheeler, the Vee2, and the cage (since it sits for weeks at a time when I'm commuting on the Vee2).
Interesting story about the battery in the cage. I have a dashcam that records while parked. This of course taxes the battery because it discharges a bit more than it should. Even though I will drive it for an hour at a time to charge it up, it will progressively get a weaker and weaker start cycle. Until eventually when I get in the car it says "System shutdown to conserve battery". It always starts, but once I get close to or receive that message, I hook it up to the PulseTech for a couple of days and it is good to go again. I wish someone offered a reasonable AGM battery that would drop in for that thing, I'd buy one in a heartbeat. As it is I'd have to modify the battery box, or buy the one and only current direct replacement option that is about $450 (cheaper to just abuse the stock battery - I can get 4 of them for that much coin). Which I don't understand for two reasons... 1) Ford uses that same battery in a zillion cars / trucks / etc. - the aftermarket should be all over that! 2) Why is a modern new car (and zillions of others) furnished with a battery technology from 50 years ago? It is not even maintenance free! Yes, I have to pop the top to check and add distilled water... Come on, where's my AGM? While not necessarily an actual deep cycle / starting hybrid battery, at least the AGM would handle the minor discharges from the dashcam better than the stock battery.
The PulseTech is a bit pricey, typically about $70. But it has paid for itself already by restoring my neglected / abused batteries that would have otherwise required replacement. However, all of this will only help an otherwise healthy battery. It only claims to remove the sulfates, it can't restore used up lead plates or fix bad internal connections.
View Post
Sponsored Links | |
Previous Thread
Next Thread
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
bike does not start, starter or battery? please help if you can! | Teskio | DL650 and DL650A - 2004 to 2011 | 39 | 12-18-2015 07:04 AM |
how often can you start the engine before battery goes dead? | culturedape | Maintenance, Tech and Products. | 37 | 05-01-2013 10:24 AM |
Should I get a new battery? Also questions on how to jump a dead battery | arooni | General V-Strom Discussion | 31 | 07-13-2011 05:29 PM |
You CAN push start a 'Strom... Battery question | rockitcity | General V-Strom Discussion | 16 | 12-07-2009 11:52 AM |
Sparking battery trying to start up | bobosmite | V-Strom Service and Maintenance Questions and Discussions | 20 | 01-11-2008 11:15 AM |
Posting Rules | |
