Parts for the factory center stand? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 11-14-2018, 12:49 AM Thread Starter
GeekPriest's Avatar
Hi. I got a good deal on a used Suzuki center stand for my 2010 Wee.
However, I need the assorted hardware to get it attached to the bike. My searches so far give me the part number for the entire kit.
Does anyone have a list of the parts that come with the factory center stand?
Thanks.
GeekPriest is offline
post #2 of 4 Old 11-14-2018, 03:45 AM
GP, oem Suzuki accessories, like a center stand, are only available in complete kit form, and there are no part numbers for fasteners, springs, hardware, nuts and bolts, etc. My Vstrom1000 came with the installation manual which does show a parts list...but the parts have no part numbers. If I remember correctly, the bolts are 10mm X 1.25 thread pitch, washers and nuts if needed will be 10mm ID, you may be able to get a spring that will work at a hardware store or bike salvage yard. The hardware is black oxide-coated. The biolt lengths may not be the same for your 650. I do not know if there is a specific bracket for your kit with a spring anchor, and a rubber pad is part of the kit for the center stand to retract to when not in use. Perhaps an aftermarket centerstand kit would be the way to go. For nuts and bolts in various lengths, diameters, and coatings I use Fastenal stores.
MAZ4ME is offline
post #3 of 4 Old 11-14-2018, 11:17 AM
Stalky Tracker's Avatar
Here's a list of parts, but like MAZ4ME said no part numbers. This is for a 2006 Wee. Also, not sure there was a 2010 model Wee in the USA, not that it should matter.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #4 of 4 Old 11-15-2018, 02:48 AM
Gert's Avatar
In general, the center stands are similar when it comes to installation. SW-Motech have an instruction guide, that may be of assistance, https://sw-motech.com/en/products/sa...2572006931.htm.
Gert is offline
Easiest Center Stand to Install Numbercruncher DL1000A - 2017+ 17 04-14-2018 09:43 PM
Great Parts and Add On Upgrades for the DL650 and DL1000 SV Racing Parts SV Racing Parts 0 10-22-2017 04:20 AM
Happy Trails Center Stand Install johno_SLC Maintenance, Tech and Products. 0 09-29-2016 05:38 PM
New SV Racing Parts, Adjustable Height Stem Lift Front Stand for All Vstrom Models. SV Racing Parts SV Racing Parts 6 04-22-2014 02:54 PM
Center stand failure DayTrippin General V-Strom Discussion 45 03-08-2011 09:58 AM
