Bike Stutters, Headlight Stops Working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
LinkBack Thread Tools
Old 10-20-2017, 10:45 AM Thread Starter
ked
took a ride yesterday. my brother was riding my Wee. we stopped at a light and when he took off, the bike sounded sorta like he was in 2nd or 3rd gear. it was a little different, like it was miss firing. anyway, it returned to normal after 5 seconds and we went down the road. we pulled over after a mile or so, to look over the bike. well, neither Hi/Lo headlights were working. bike seemed fine, so we took off. the lights started to work, and bike seemed ok.
i don't believe it "healed" itself. where should i be looking to find the problem?
thanks, Keith
if a man speaks, and there isn't a woman around to hear him, is he still wrong?:confused1:
ked is offline
Old 10-20-2017, 11:00 AM
Headlight problems are covered at https://www.stromtrooper.com/informat...-problems.html
That is usually a start switch contact or sometimes a bad connection. The running problem can also be a bad connection but may be a charging system problem leading to low voltage or a bad battery. Put a voltmeter on the battery leads and check with the ignition off, at idle and at or above 3000rpm. Let us know the results but check against the following table.
Old 10-20-2017, 07:54 PM
Rolex's Avatar
Check the battery terminals are tight, they tend to work loose on bikes.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
