My plan for my V (next time I tear into the dash wiring) is to wire in power for the flasher circuit, an underseat USB outlet, and maybe the 12v dash socket to the parking light position on the ignition switch instead of the lights. (can't ever see using "parking lights" for anything. It would be handy to charge something while away from the bike, so that would allow the key to be absent.
You could consider a more simple approach. I have SAE connector direct to the battery that come out under the left side of the seat. I have a toggle switch for it mounted to a through-hole in the plastic panel that runs along the bottom of the seat area. It is handy to reach with my left hand while riding. I use that SAE plug for my heated gear, my battery tender. And if I need to charge my phone or video camera I have a store-bought SAE to dual USB. It came with a 8 -10 inch cord so I can put my phone under the seat (locked) to charge while I'm in a restaurant etc. I see it as a trifecta without mucking up my wiring harness.
Member: AMA
