F1 Flashing and getting a -c00 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Frogestil
post #1 of 9 Old 11-12-2019, 10:54 PM Thread Starter
Frogestil's Avatar
Hey guys. I have a 2018 DL1000A ABS model and the check engine light is on with a flashing F1 on the dash. No other lights are on. I’ve put it in dealer mode and I’m getting the -c00 code. I’ve disconnected the battery for a few minutes while I checked all my fuses. And it’s still there regardless if the motor is running. Everything seems good. Motor runs fine. I read a thread somewhere saying that there is an ABS diag connector somewhere. My ABS light is not on but I figured why not. Nothing else is producing a problem to be addressed. I’ve searched this forum and have read so many threads, just nothing like what I’m experiencing. Any ideas?
Frogestil is offline
post #2 of 9 Old 11-13-2019, 01:29 AM
Did you ride it on anything other than dry pavement recently?
Gavinator is offline
post #3 of 9 Old 11-13-2019, 05:33 AM
twenty's Avatar
is it out of warranty?
twenty is offline
post #4 of 9 Old 11-14-2019, 10:51 AM Thread Starter
Frogestil's Avatar
I rode it down to a campsite but it didn’t get wet or anything. Just dirt roads. It is in warranty but it’s my only form of transportation so if I could figure it out myself... you get it. It was below freezing the 2 nights I was down there but when it warmed up, there was no change. Still a code with no code.
post #5 of 9 Old 11-21-2019, 10:52 AM
dannyg's Avatar
check for a rock or something in the exhaust flapper valve or whatever it is called. Happen to me.
dannyg is offline
post #6 of 9 Old 11-21-2019, 07:06 PM
NVDucati's Avatar
Hi, Have you gotten it fixed ?
If not, check the clutch safety switch. Jiggle it / remove, clean and reinstall or just replace it. They are not expensive and are know to partially fail. That switch talks to the EMU. I carry a spare under my seat.
Member: AMA
NVDucati is offline
post #7 of 9 Old 11-22-2019, 01:55 AM
Grimmer's Avatar
...I read a thread somewhere saying that there is an ABS diag connector somewhere...
The ABS diagnostic connector is in the under seat compartment on the right side (when looking forward toward the front tire, i.e. the "starboard" side). It's taped to the wiring harness that goes to the tail lights. Or, at least it is on the 2014 DL1000. Not sure if it still in the same place on the 2018.
Grimmer is offline
post #8 of 9 Old 11-22-2019, 03:57 PM
Rolex's Avatar
I had to adjust the exhaust valve on my 2014, the cables had stretched a little, I have had no issues since.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #9 of 9 Old 11-23-2019, 06:53 AM Thread Starter
Frogestil's Avatar
Ok, just an update. If you get the FI flashing and when you put it in dealer mode and get the -c00, look at your exhaust. My problem ended up being a rock that was in the exhaust pipe valve cover causing havoc. That valve couldn’t operate correctly. It was enough to run fine and ride fine but also restricted movement enough to make the FI flash with the check engine light on. When you turn the key on and watch that valve, it will cycle both ways. If doesn’t do that cycle like it should, hello FI.
NVDucati likes this.
