"Easy Start" not that easy - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #1 of 49 Old 10-19-2019, 06:19 AM Thread Starter
bosnjo's Avatar
My last model DL1000 was one of first fabricated. I've got good deal on it but I knew it would come with some problems. One of them was air entering front brake system. That one was solved after 6 months of troubleshooting.
But there is one more. "Easy Start" sometimes simply refuses to work. I press the start button and - nothing. If I squeeze the clutch it turns and starts no problem. On ocasions when Easy Start is not working I also have to keep the start button pressed, just like on my previous '14 model.
I mean, it's not big deal. I don't really need it and it's just intermittent fault. My dealer really tried hard but canīt find anything.
The bike is not under warranty anymore but I made sure to make complaint about this one while it still was.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #2 of 49 Old 10-19-2019, 09:32 AM
slovcan's Avatar
Easy Start? Mine is a 2002. I always pull the clutch lever in before starting the engine - always have on all my bikes and cars. I figure there is less mass for the starter motor to spin that way. That said, I have tried cranking the V-Strom a few times without disengaging the clutch and nothing. Do you mean it SHOULD start in neutral without pulling the clutch lever in?
Cheers,
Glenn
Motorpsychology likes this.
Anything can happen in Formula 1 and usually does! - Murray Walker
Here - 2002 V-Strom DL1000, 1999 Triumph Trophy 900, 2003 Maxima SE 6-Speed, 1997 Silverado K2500 - 454
Slovakia - 2004 Rover 75 CDT Tourer w/ Tuning Box
Past - 1977 Honda 400/4 Supersport, 1982 Honda CB900 Custom, 1984 Honda V65 Sabre (TWICE), 1996 Kawi GPz1100, 1990 Honda VFR750F
slovcan is offline
post #3 of 49 Old 10-19-2019, 10:03 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
For those like me that never heard of "easy start." https://www.globalsuzuki.com/motorcy...strom1000a_xt/
Conventional starter switches needed to be pressed by the rider until the engine starts, but the new V-Strom 1000 ABS has adopted the Suzuki Easy Start System enabling the engine to start with one push of the button. A computerized ECM checks the status and disengages the starter motor immediately after start.
・Not available on the North American Spec
I would still think that you would need to pull in the clutch.
slovcan likes this.
richlandrick is offline
post #4 of 49 Old 10-19-2019, 10:26 AM
I suppose the new generation is having a bit of a problem with thumb strength . Too much texting , perhaps ???
Big B, Motorpsychology and slovcan like this.
2014 DL1000 - Sold
2010 Triumph Scrambler- Sold
2014 KLR650 - Sold
2017 Honda CRF250L - current
2016 Honda VFR1200X - current
Slow Eddie is offline
post #5 of 49 Old 10-19-2019, 10:27 AM
Griff2's Avatar
The clutch still needs to be pulled on my 2016
slovcan likes this.
Griff2 is offline
post #6 of 49 Old 10-19-2019, 11:03 AM
slovcan's Avatar
Thanks guys. I can say from this that my 2002 does not have an Easy Start system. I guess the clutch switch must also be closed to complete the start circuit. That's OK with me.
Cheers,
Glenn
slovcan is offline
post #7 of 49 Old 10-19-2019, 06:40 PM Thread Starter
bosnjo's Avatar
Easy Start for VStrom was introduced only on the latest model. That means model fabricated sometimes mid 2017 and afterwards.
I was not aware of the feature missing on US bikes.
However, I can't count on mine anymore.
2017 DL1000 White
bosnjo is offline
post #8 of 49 Old 10-20-2019, 12:31 AM
Solution in search of a problem? Iíve never understood the point of easy start.
Houstrom46* is offline
post #9 of 49 Old 10-21-2019, 07:21 AM
Griff2's Avatar
I have a feeling that the feature is also incorporated in the ECU that some of the earlier models of 2014/2016 were retro fitted with.
Griff2 is offline
post #10 of 49 Old 10-21-2019, 09:59 AM
MeefZah's Avatar
My easy start doesn't work (2018), never has. One of several advertised features that are false representations... the other glaring one is "aluminum fat bar" (it's steel).
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
