Booster Plug - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 12 Old 09-02-2019, 12:17 AM Thread Starter
Bully's Avatar
Booster Plug
Hello All,
I currently own a 2017 DL1000 and I'm on a mission to reduce the harsh engine braking when decelerating. The throttle has been overly snatchy from new and with the addition of a G2 Throttle Tamer it has helped enough for me to tolerate this problem when riding solo. However, when riding 2 up, the effort required to finely control throttle openings/closings and the amount of clutch slipping required to keep the ride smooth is ridiculous. The overly strong engine braking with the smallest throttle close when decelerating feels even worse with a pillion. I'm looking for a fix and a bit cautious of getting the ECU flashed while the bike is under warranty. The Booster Plug looks promising and I'm just looking for some honest feedback into how effective it is at sorting the issues I've raised, especially with the 2017 DL1000's onwards. Your thoughts appreciated!
Thanks in advance,
Bully is offline
post #2 of 12 Old 09-02-2019, 01:00 AM
uscgmac's Avatar
I have a 2018 and never felt the throttle was snatchy at all. In fact I think it's one of the more tame and smoother throttles I've had.
Sent from my SM-J700T using Tapatalk
uscgmac is offline
post #3 of 12 Old 09-02-2019, 02:44 PM
I have a 18 also Throttle Tamer helped what little throttle "Snatch"it had. Booster plug make no Diff. how it ran save your money....
Norm
Riding for 60 years
Current Rides
2018 Suzuki DL 1000 ADV.
2010 Yamaha XT250
2005 BMW R 1200 RT Gone
2011 Suzuki DL650 Gone
Plus 43 other Dirt and Street Bikes from AJS to Harley in my past...
Old Codger is online now
post #4 of 12 Old 09-02-2019, 03:18 PM
NVDucati's Avatar
I'm a big fan of the BoosterPlug. You can find some previous posts by me and others.
The short answer, from me, is do it. Don't accept any cheaper alternatives.
https://www.stromtrooper.com/5305947-post7.html
It turned my V2 into the bike I was hoping I had bought.
Member: AMA
NVDucati is online now
post #5 of 12 Old 09-02-2019, 04:58 PM
basshead's Avatar
I had the booster plug, made a very small difference and was having high fuel consumption in cold weather.
Since I flashed the ECU (Woolich Racing) and turn off the fuel cut on decel, it's another bike. On my daily commute I spend 60% of the time in 1st and 2nd because of the traffic and couldn't stand the decel on this bike. The throttle tamer took care of the acceleration part, but still have an issue when sitting in traffic for a few minutes the clutch friction zone get very narrow, making slow speed acceleration more challenging. I need to test different oil brand/grade to see if it help, but maybe your 2up riding make the oil run a bit hotter and you have a similar issue?
2018 Yellow DL1000
basshead is offline
post #6 of 12 Old 09-02-2019, 06:37 PM Thread Starter
Bully's Avatar
Thanks everyone.
Bully is offline
post #7 of 12 Old 09-05-2019, 08:17 AM
Bazooka Joe's Avatar
Bully,
Check out this thread.
https://www.stromtrooper.com/dl1000a...ottle-off.html
My bike had a lot of compression braking, snappy/abrupt response throttle at partial openings at low rpm- almost obnoxious, but yet at the same time, the engine didn't pull well at lower (below 3k) rpm.
After I adjusted the TPS per the discussion in the reference thread, my engine runs much better. Less compression braking, substantially less snappy throttle at lower rpm, smoother roll on throttle response at lower rpm, chugs down low much better, etc., and it also seems to rev out better too (which seems like a coincidence?). As an unexpected bonus, it shifts better between 1st and 2nd gear- must be something related to the lesser compression braking or smoother engine running. I never would have expected such a slight TPS change would be this substantial change. I've adjusted TPS on Yam dirt bikes in the past, but it didn't change much if anything.
Anyway, check your TPS per the instructions in the thread. It's easy to check your bike's setting, and the adjustment isn't a very difficult task.
Hope this helps.
Cryoman likes this.
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is online now
post #8 of 12 Old 09-05-2019, 08:40 AM
fig
fig's Avatar
Thatís one of the things I loved about this bike. I use engine braking. When I had the complimentary ecu recall done the engine braking was extremely diminished. I was furious. I would say it was cut by 50%. The only thing they could do to change was put the old ecu back in. I didnít want to go back to the ďstallingĒ issue so I had to live with it.
Maybe take a look at your ecu and see if you somehow ended up with a left over.
I also just put some Shinko 804/805ís on and the engine braking has diminished even more. I donít think itís an ecu result, I think itís the soft compound and heavy knobby doing it. I am now kicking down 2 gears to brake. So this might be an option for softening the engine braking for you if you can tolerate bias tires.
fig is offline
post #9 of 12 Old 09-05-2019, 09:31 PM
Rolex's Avatar
I fitted and custom tuned a PCFC along with a throttle tamer so I have no snatch but I found for smoother ride especially two up I don't back the throttle off between gear changes.
My brother rides my old Wee and he has been happier too since I told him this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #10 of 12 Old 09-05-2019, 09:47 PM
scab's Avatar
Sorry, original comment was for the wrong bike.
If you're not living on the edge, you're taking up too much space.
scab is offline
