Booster Plug - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #11 of 16 Old 09-15-2019, 07:06 PM Thread Starter
Bully's Avatar
After no success with the TPS adjustment I purchased a Booster Plug. In my opinion it's the best money I've spent on this bike so far. It has virtually eliminated all of the problems I described in my earlier post. I do have a Throttle Tamer fitted as well and it's possible that one compliments the other but regardless I'm very happy with the result. The only con I can think of is that when the bike is at idle you can really notice the richer fuel mix by smell but that's about it.
blaustrom, NVDucati and Webfors like this.
Bully is offline
post #12 of 16 Old 09-15-2019, 10:14 PM
Webfors's Avatar
Thanks for the report. Ever since I installed the Dominator slip on the bike doesn't start as easily and tends to lug slightly under 3k rpms. I suspect slightly richer fueling would solve it.
Two wheelz for realz!
'18 DL1000XT
Webfors is offline
post #13 of 16 Old 09-19-2019, 05:15 PM
Webfors's Avatar
The deed has been done.
I didn't think it was possible to get more torque grins down low. Too funny...
Other than having to lift the tank, the install took 5 minutes.
I can cruise along in the burbs at 2k rpm now... and she makes an angry growl when you twist the throttle down low.
I'll keep you posted
blaustrom and NVDucati like this.
'18 DL1000XT
Webfors is offline
post #14 of 16 Old 09-19-2019, 11:13 PM
Webfors's Avatar
Got 60km in tonight. I'm not sure what to say other than this is how the bike should run from factory. I have to adjust my throttle input in the low rpms and start modifying my gearing accordingly. Starts like a charm and still kept its' after market exhaust burble on decel (which I liked). That small decrease in the AF ratio has made a big difference IMO.
Next up the cruise install and then I'm calling it quits on farkles until next year... or maybe after some LED bulb swaps
'18 DL1000XT
Webfors is offline
post #15 of 16 Old 09-22-2019, 10:32 AM
new owner of '18 dl1000 here.... had it about a month....
snappy throttle, yes - largely manageable - but one of the things that has struck me was how much less engine braking it has compared to previous liter bikes (st2, st4s, 1150gs).... this thing is smooth, nimble, & quick enough - grin factor approaching the ducs - i like it....
Webfors likes this.
vsboar is offline
post #16 of 16 Old 09-30-2019, 12:00 AM
I’m surprised how many think this bike has a sensitive/twitchy throttle. Ride and KTM street/adventure bike and you will think the Suzuki is smooth as butter
Webfors likes this.
TJSTRONG is offline
