25k Mile Check-In for 2018 V Strom 1000XT - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 19 Old 08-12-2019, 06:38 PM Thread Starter
Just wanted to share that my 1 year old V Strom 1000XT 2018 is doing well @ 25k miles. My goal is to see 200k. I am inspired by all the high mileage riders on this forum.
A few of the trips big trips I've done with it from north eastern PA:
California
Florida Keys
Gaspe Peninsula
Near Future Rides Planned:
Upper Peninsula is slotted for Labor Day Weekend 2019
Alaska - Summer 2020 (I really hope)
Next week I will be mounting my 5th set of tires on the bike. The tires I used are as followed:
1. OEM Tires (8k miles)
2. Heidenau k76s (8k miles)
3. Shinko 705s (4k miles, but the worst front tire I have ever used)
4. Heidenau k76s (5k miles, but a lot more 2up riding than the first k76 set)
Chain replaced @ 20k miles, which was a little premature, but I had a 3k mile ride that I wasn't comfortable trying to squeeze the miles out of a worn chain.
Oil used: Motul 300V 10W-40
Bled the brakes twice, which was at a 10k mile interval. Pads are good
OEM seat is comfy as hell.
OEM suspension is feeling pretty worn. Time to start looking for some aftermarket options.
My only real issue was a fluke broken foot peg casting, which wasn't covered by warranty.
tenny80 and Nicad like this.
Suzuki V Strom 1000 XT - 25,000 miles. Hoping to rack up 200,000+
Yamaha FJ09 2015 - 37,000 (Blew Up)
Honda Grom 2014 - 15,000 miles
vinnie is offline
post #2 of 19 Old 08-13-2019, 07:10 AM
MeefZah's Avatar
Was the footpeg mount broken in a fall?
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #3 of 19 Old 08-13-2019, 08:29 AM Thread Starter
The bike didn't fall over. There was a hairline crack in the footpeg plate casting and the bike was only about a week and a half old. My awful local Suzuki dealer insisted it had to have been from a fall and they've never seen anything like that (as always), but it might have been from rolling it out of my garage and catching the side of the house with the peg.
vinnie is offline
post #4 of 19 Old 08-13-2019, 12:37 PM
Spec's Avatar
Going to check the valves?
Might want to if your goal is 200K miles on that motor!
Spec is offline
post #5 of 19 Old 08-13-2019, 01:36 PM
blaustrom's Avatar
Originally Posted by vinnie View Post
...OEM suspension is feeling pretty worn. Time to start looking for some aftermarket options. ....
Send your forks and shock to DMr Performance Suspension ? Performance Motorcycle Suspension and Chassis in the offseason. You will like the result. There are other companies doing similar work.
Motor7 likes this.
Ö....
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is online now
post #6 of 19 Old 08-13-2019, 04:29 PM Thread Starter
Yes, checked them at 14k, I believe. Due for another check next month, after Labor Day Weekend.
vinnie is offline
post #7 of 19 Old 08-13-2019, 04:33 PM Thread Starter
The problem is I ride all year round. I will check it out though. I might have to schedule some time off from riding the strom, if it's cost effective enough.
I barely started looking, but I was hoping to find a replacement rear shock, without breaking the bank, and inserts for the forks that I could do myself.
vinnie is offline
post #8 of 19 Old 08-17-2019, 09:53 PM
uscgmac's Avatar
I don't know how you did all those miles on the stock seat. I just replaced mine after one long day in the saddle. I went out and got a Sargent seat. That stock seat is torture after several hours.
Sent from my SM-T350 using Tapatalk
Motor7 likes this.
uscgmac is offline
post #9 of 19 Old 08-18-2019, 07:57 PM
Did a small trip 3200km in 5 days. With the oem seat.
I'm what you call call an iron butt.🤣😉
2018 Vstrom 1000 XT yellow stinger
pete4x4 is offline
post #10 of 19 Old 09-25-2019, 10:06 AM Thread Starter
Valve clearances were checked for the second time. The same front exhaust valve that was .0015 inch tight (out of spec) was .001 inch tight again. I did all the work at my friend's motorcycle shop, except the valve clearance check and one valve adjustment; I left that to the pro because it's one of my least favorite things to do.
1.5 hours to get the bike down to the valve covers
1 hour of checking clearances, looking up specs, remeasuring clearances, and adjusting the one valve
2.5 hours to get it back together, but I wasted time with dumb small issues like not being able to get the air box rubber boots back on the intake. That was a pain.
We adjusted the valve back to spec and if the valve moves that much again, going to need to do a upper engine rebuild (at least on that cylinder). I feel like I always get a bike that has valve issues. Disappointed that the rock solid v strom might not be so rock solid in the near future.
Plan was to ride up to Alaska next summer, but I'm not sure if that makes sense with a potential valve issue looming. I don't have 14k miles planned between now and then, but I would at least have to check the valves again a month or two prior to leaving.
vinnie is offline
