Notes/Questions after test ride - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #11 of 16 Old 08-06-2019, 04:23 PM
nvr2old's Avatar
Originally Posted by n8tdi View Post
Thanks nvr2old. Did the peg lowering kit reduce the max cornering angle much?
I'm semi-agressive at times in the turns and have never even touched a feeler.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #12 of 16 Old 08-08-2019, 12:56 PM
"I'm semi-agressive at times in the turns and have never even touched a feeler."
Show me your chicken strips...
I'm not aggressive as such and have touched the stock pegs occasionally. I got shorter DR pegs and haven't hit those anymore.
post #13 of 16 Old 08-11-2019, 05:38 AM
MeefZah's Avatar
All the stuff that seemed off to you is actually normal for the engine / chassis / bike.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You cant grasp its vastness from a plane. Its diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #14 of 16 Old 08-11-2019, 11:13 AM
blaustrom's Avatar
Factor in to change (upgrade) the clutch basket (Werks). The V2 basket is just as primitive as the original VEE basket and causes vibration in the 3-4k range. With the modified basket the engine is much more pleasant and not much different than the 650. What I called the "agricultural nature" is pretty much gone. Also consider adding a booster plug and you can accelerate from 2k on out! Its a sweet ride now!
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #15 of 16 Old 08-12-2019, 01:32 PM
Spec's Avatar
Or instead of spending $500 just ride around above 4K rpm!
The motor is happier there anyway.
branthopolis likes this.
Spec is offline
post #16 of 16 Old 08-12-2019, 03:25 PM
branthopolis's Avatar
#3 can be improved by installing a shift arm linkage from a TL... The arm is shorter which leads to a shorter throw at the lever. less false shifts and a crisper feel...
Part #23 on the diagram.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
