does the first to second shift get better with miles? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 15 Old 07-20-2019, 10:45 PM Thread Starter
does it? I have 900 miles on the bike with non syn castrol motorcycle specific 10-40 and first to second is not smooth at all. preloaded shifter, its OK. Will this get better with time? When I go to syn will it help?
ZRX4ME is offline
post #2 of 15 Old 07-21-2019, 12:29 AM
kd70qc's Avatar
Mine (650j seems pretty notchy at times. I dont remember how it was new. When my oil gets dirty, or with yamalube it seems notchier then with fresh or other oils. Since you are in Florida, you might try 20w50 Suzuki oil at your 4,000 mile oil change.
ZRX4ME likes this.
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #3 of 15 Old 07-21-2019, 12:33 AM
nvr2old's Avatar
Different oils seem to effect shifting differently. Not always synthetic, but the longer its in the more shifting get rougher.
Also, yes, a new engine is stiffer and improves with miles.
PS- I use 15-50 Mobil 1 since the 600 mile change.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 15 Old 07-21-2019, 01:37 AM
Rolex's Avatar
I have read that some have that trouble, my 14' has been great but keeping the chain lubed up smooths things out just a little.
I will own the fact that rarely lube my chain so that don't help.
Check your gear leaver is in a good position for you and it is well lubricated too.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 15 Old 07-23-2019, 01:25 PM
twenty's Avatar
I always preload, especially up shifts. why not just continue preloading? faster, smoother shifts and no false neutrals etc...
i purposely tried not preloadong on my way to work this am and had one or two clunkers between 1st and 2nd. may have been my awkward technique, not giving it enough force or the gearbox. i only have 4k km on it and am running a semi oil.
twenty is offline
post #6 of 15 Old 07-23-2019, 01:40 PM
RCE1's Avatar
The legendary Kari Prager, may he rest in peace, suggested once that I'd have better luck if I short shifted between first and second rather than running any higher revs in first. He was talking about me riding my BMW R1100GS at the time, but it really helped me out a lot.
RCE1 is offline
post #7 of 15 Old 07-23-2019, 01:56 PM
Mine did seem to smooth out, but as precaution i always preload, especially 1-2. if not, i shift at a lower rpm as others said.
Oils did make a big difference for me, with Mobil being shifting the best on my particular bike.
I thought a got a clunker, literally, when i first started driving it. But with a combination of the above i feel its normal now.
ZRX4ME likes this.
2016 DL1000 ABS
ERockJL is offline
post #8 of 15 Old 07-23-2019, 04:17 PM
Null 13's Avatar
In my experience, no, it's the opposite.
My lil guy likes it when i gear up with authority (not to be confused with forced lol), when i'm too smooth it can end up in neutral or will hop off of second gear as i give it gas (last one is rare, but happened a couple times).
Was told it was normal, more than once, so i made my peace with it
ZRX4ME likes this.
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is offline
post #9 of 15 Old 07-25-2019, 08:26 AM
Griff2's Avatar
Keep the chain properly adjusted to begin with. A too loose chain will contribute towards poor gear changes.
Some bikes improve with mileage and others don't. A former KTM had a notchy gear change from the getgo and it never went away. My current 2016 Strom could be a bit notchy twixt 5th and 6th but in fact that is improving and only now occasionally appears at 12,000kms. I think the cause is a poorly machined gear where the dogs of the mating gear have difficulty slipping into place. With time and plenty of use the imperfection can get polished out and the change gradually improves. I suggest that You make sure to be positive and firm with the change and if it is still a major issue with about 5000 miles on the ODO then take it up with the dealer.
A poorly disengaging clutch can also contribute. That too can improve with mileage as the clutch plates get more comfortable with each other.
Griff2 is offline
post #10 of 15 Old 07-25-2019, 01:47 PM
Webfors's Avatar
My '18xt has a real slamming 1-2. I just giv'er and ride.
The 20w50 Valvoline conventional did seem to help.
Big B likes this.
Two wheelz for realz!
'18 DL1000XT
Webfors is online now
