'18+ Heated Grip Adaptor..? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 13 Old 06-30-2019, 10:08 PM Thread Starter
Webfors's Avatar
Looking to install heated grips. On my '15 650 I used an Eastern Beaver adaptor cable to plug into an OEM circuit specifically for heated grips.
Does the same apply to the '18 DL1000?
Two wheelz for realz!
Webfors is offline
post #2 of 13 Old 07-02-2019, 02:47 PM
tenny80's Avatar
Yes I believe it does. I use the Oxford heated grips and they shut off when the battery reaches a certain level. They plug right into the battery, works really well.
Webfors likes this.
2018 Vstrom 1000
tenny80 is offline
post #3 of 13 Old 07-05-2019, 02:19 PM Thread Starter
Webfors's Avatar
Did you plug them directly into the battery or use the OEM HG circuit/plug?
Webfors is offline
post #4 of 13 Old 07-05-2019, 02:33 PM
Byronw's Avatar
I just installed the Oxford Heaterz on my new to me 2014 DL1000, and went right to the battery with the terminals. I tested the auto off feature in the garage, works fine. General consensus here is that works well, and has not failed or left anyone stranded with a dead battery.
On my 2012 DL650, I wired the grips to the accessory plug behind the radiator with an Eastern Beaver connection, but they didn't have the auto off feature.
Webfors likes this.
Byronw is offline
post #5 of 13 Old 07-06-2019, 08:57 PM
To the op - I just used an EB adaptor to power my GPS with the factory heated grip connector. It was hard to find, if you have the tank off you can see it from above @ 11 oclock inside the frame behind the radiator. You can fish it out without removing anything, just barely from the left bottom, as it is heavily taped. Test with a meter to identify the 12v side after you plug in the adapter.
Webfors likes this.
2006 DL 650
2018 DL1000A
jmvs is offline
post #6 of 13 Old 07-06-2019, 11:47 PM
Rolex's Avatar
If you have trouble picking up a switched power supply to operate a relay or a EB power supply the horn is a easy place to get it.
Just a piggyback terminal on the power side of the horn.
The horn operates by having switched positive power to one side and the button gives it the earth required to make noise.
Webfors likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 13 Old 07-07-2019, 01:27 AM
The newer Oxfords actually recognise when the engine is not running and shut down on a timer rather than when voltage drops.
After a few minutes they go into standby then shut down a few minutes later.
This allows short stops such as for fuel without having to reset them.
Webfors likes this.
portly is offline
post #8 of 13 Old 07-07-2019, 11:02 PM
Rolex's Avatar
It is the voltage drop that tells the controller the bike has stopped, then the timer takes over.
Webfors likes this.
2014 V2, Snoopy
Rolex is offline
post #9 of 13 Old 07-09-2019, 07:28 PM Thread Starter
Webfors's Avatar
Interesting... when you say "newer"... how new and how can I tell I ordered the new one?
Webfors is offline
post #10 of 13 Old 07-10-2019, 01:28 AM
Rolex's Avatar
Mine would be about 5 years old I think ??? and they have that feature.
Webfors likes this.
2014 V2, Snoopy
Rolex is offline
