couple of newb questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 17Likes
post #1 of 29 Old 06-10-2019, 04:44 PM Thread Starter
twenty's Avatar
after installing the center stand it's now easier to get an accurate oil level rather than just a go / no indication.
where should the oil be in the fill window if you used the prescribed volume for an oil / filter change?
any possible harm from running it right on the top line?
why does the rear axle nut have notches on the outside if it's not a reverse thread? maybe I'm missing something but that's always been an indication of left handed threads.
chain tension specs seem a little tight to me at the bottom end. I adjusted it to the top end of the spec but was wondering if people run them a little looser?
i did try the search function but didnt find anything on these, thanks for any help
twenty is online now
post #2 of 29 Old 06-10-2019, 04:47 PM
Lrobby99's Avatar
I like to see a little space between the oil level, and the top of the sightglass, myself.
Give that chain a little slack, but if this bike is brand new it will loosen up a bit anyway.
Lrobby99 is offline
post #3 of 29 Old 06-10-2019, 04:54 PM
V-Tom's Avatar
Greywolf used to always suggest that it looks more full than it actually is when filling on the centerstand because it raised the back a bit compared to the front. So yes fill it right to the top of the sight gauge if it is on the centerstand.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #4 of 29 Old 06-10-2019, 04:55 PM
Castellated nuts ( the ones you put cotter keys through the cutouts in the outer portion of them ) are not exclusive to left hand threads. They are simply a way to positively secure a nut against loosening. Quite common on fasteners that need an extra measure of safety.
A chain a bit on the loose side is ALWAYS better than one that is any too tight! There can be tremendous forces transferred to the bike from a too tight chain. Something has to give!
realshelby is offline
post #5 of 29 Old 06-10-2019, 05:04 PM
PerazziMx14's Avatar
As long as you can see oil in the sight glass you are okay. Filling it to the top or just below the top of the sight glass give you no benefit. Shooting for the oil level to be in the 1/2 to 3/4 the way up the sight glass is ideal.
For the rear axle nut are you talking about a castle nut. Where the nut has cutouts and the axle has a whole in it to install a cotter pin to keep the nut from loosening and or tightening. For the record the axle nut is a standard right hand thread.
Chain tension should be checked at several places. Mark one link check the chain tension and take note. Rotate the wheel one turn and check the tension again and take note. Do this as many times as it takes to get the marked link back to where you started. Then adjust the tightest part of the chain to 1.25 to 1.5" of slack.
Byronw, Grimmer and Webfors like this.
PerazziMx14 is online now
post #6 of 29 Old 06-10-2019, 05:20 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Way too much oil causes oil foaming. Oil foam is oil with air bubbles. Oil with air bubbles does not lubricate or transfer heat anywhere near as good as oil.
Dark Angel and Grimmer like this.
richlandrick is offline
post #7 of 29 Old 06-10-2019, 05:46 PM Thread Starter
twenty's Avatar
not a castle nut. notches on the points of the flats. I need to find a photo hosting site, let me see if I can find an example.
thanks for all the replies
post #8 of 29 Old 06-10-2019, 06:01 PM
STCorndog's Avatar
On a new fill with oil, I shoot for the top line every time and am happy if it is at full or even over. I do like to see a tiny air gap above the oil. These bikes almost all use a little oil. Why start out below full?
There is also some, including me, that feel the more oil in the bike, the more the oil will contact and cool the stator. On a dry sump engine, oil foaming is not typically an issue as the crank does not sling oil like a wet sump design.
As for checking on a center stand, that is fine, but slide a thin board under the front wheel until the bike wheels are equal distance from the floor. Yes I am OCD.
STCorndog is offline
post #9 of 29 Old 06-11-2019, 06:27 AM Thread Starter
twenty's Avatar
thanks again for all the replies.
I was curious about the oil level because it was the first time i could properly check the shops work. I assume they used the proper quantity of oil but saw that the sight glass was half full warm (slightly less cool). they charged for 4L, so I was wondering why they didnt fill it right to the top indicator. I like to fill it right to the top line, just makes it a simple check before each ride. stand the bike up and lightly rock it while looking for the little bubble at the top of the sight glass.
the bikes got 1700km and the chain was at 1.75", didnt seem too loose but thought I'd bring her a little closer to spec. the manual says .8" - 1.2", .8 sounds way too tight so I adjusted to 1.25". thanks for the tips, sounds like I've got it in the right range.
the axle nut markings aren't important, though it makes me wonder why two people mentioned castle nuts.... do your bikes have them? I'm going to try and attach a small pic, looks like the forum will let me..... maybe. I'm guessing these notches now indicate a type if locking nut but to me the signify left hand threads.
any suggestions for a free photo sharing website?
Webfors likes this.
post #10 of 29 Old 06-11-2019, 02:56 PM
Webfors's Avatar
Any good videos on checking chain slack, that are recommended from members of the forum.
I'm almost certain that my chain was adjusted too tightly on the service before pickup of the new bike. The chain feels like it's under constant tension.. even though I can force it up and down close to an inch.
Two wheelz for realz!
Webfors is offline
