Speedometer - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 12 Old 04-07-2019, 10:34 PM Thread Starter
Speedometer
Havent bought a bike since 2013. Pick up my new 2018 V1000 soon. Have a 100 mile ride to get her home and was wondering how accurate is the speedometer?
RandyinTN is offline
post #2 of 12 Old 04-07-2019, 10:40 PM
Funny you ask. Annoyingly off. I have 2018 1000 xt and tonight I went out with gps to see how off it was. Between 30 and 70 mph it’s about 3mph off to the high. Above 70 mph it’s 4 mph high. 74 to 75 is 70 mph on gps. Debating if I should get speedo fixer gadget. Aka whatever it’s called to make it accurate but I think it messes with odometer then.
Captainmorgan70 is offline
post #3 of 12 Old 04-07-2019, 11:29 PM
Originally Posted by Captainmorgan70 View Post
Funny you ask. Annoyingly off. I have 2018 1000 xt and tonight I went out with gps to see how off it was. Between 30 and 70 mph itís about 3mph off to the high. Above 70 mph itís 4 mph high. 74 to 75 is 70 mph on gps. Debating if I should get speedo fixer gadget. Aka whatever itís called to make it accurate but I think it messes with odometer then.
If the speedometer is off, wouldn't the odometer be off as well? It's something I've wondered about on my 07 Wee, on which the speedometer always reads about 7% high.
theayn is offline
post #4 of 12 Old 04-08-2019, 12:12 AM
V-Tom's Avatar
No. Strom speedo's are off about 7 or 8 %. The odometer is within a couple of percent.
Think of speedo and odo as different devices. For various reasons Suzuki has decided to show the speedo as (about_ 8% optimistic an dhas decided to show the odo as almost right on.
..Tom
2015 DL1000 New July 2015 175,000+ km, 108,500+ miles.
SMIDSY detailed report.
V-Tom is offline
post #5 of 12 Old 04-08-2019, 02:56 PM
Big Boy's Avatar
This may help.
https://www.amazon.com/SpeedoDRD-DRD...s%2C162&sr=8-6
W. C. Fields
Big Boy is offline
post #6 of 12 Old 04-08-2019, 09:24 PM
Brockie's Avatar
Mine has always been 8% optimistic. I'm assuming that Suzuki's lawyers are the reason for it.
Brockie is offline
post #7 of 12 Old 04-10-2019, 04:54 PM
Yes, I have found that both the 2013 VStrom 650 and the 2018 VStrom 1000XT read low in terms of miles per hour. I've always chalked it up to a conversion error (kph to mph.) No idea if that is true or not, but it does consistently under report miles per hour.
TheColumbiaKid is offline
post #8 of 12 Old 04-10-2019, 05:19 PM
V-Tom's Avatar
Don't know if I am misunderstanding you or you are mistaking things. Every stock strom I have ever ridden or heard of displays the speed roughly 7 or 8% higher than the actual bike speed. Ie if the actual speed is 60 mph the speedo will display 64 or 65 mph. If the speedo displays 60 mph the actual speed is around 56 mph. If the actual bike speed is 100 kph the speedo will display 107 or 108. Kph. If the speedo display 100 kph the actual speed is 93 or 94 kph.
(Warning! Nerd talk follows: As far as conversion metric to imperial units on the digital odometer Suzuki is using .625 as the conversion from kilometers to miles instead of .6213712. This isn't noticeable on the speedo but is noticeable on the odometer when you start getting higher mileage in the bike, record the mileage and travel in both Canada and the USA. This is true on DL650 from 2012 until the facelift and also from 2014 DL1000 up to the facelift. I imagine the 2017-2018+ are the same but don't know if for a fact)
..Tom
V-Tom is offline
post #9 of 12 Old 04-10-2019, 08:00 PM
Spec's Avatar
This comes up on all the motorcycle forums I've been on.
There are regulations that state that the ODO has to be accurate and the speedo can't show less than the actual speed.
Bike manufacturers always make the speedo read high I'm guessing for liability reasons. Probably generate some class actions suits if they were 8% low!
Brockie likes this.
Spec is offline
post #10 of 12 Old 04-10-2019, 08:16 PM
jgendr's Avatar
..Tom
My 14 Wee was 10% off from actual GPS speed. I used a SpeedoHealer to correct mine. The correction factor was -9.1 and I'm about dead Nutz on now.
I beg to differ on the Odo being Different than the Speedo unless it uses the ABS Tone rings to calculate mileage. If it uses the speedo sensor on the front Sprocket it would be off by the same percentage. I am pretty sure Suzuki does it so they can Cheap out on Factory Warranty by as much as 10% multiplied by Millions of bikes sold = Major corporate Savings! sounds like class Action Suit Time to me.
Same thing happened in the Auto industry which Forced the auto manufacturers to accuratize the speedos and odo's
2014 DL650 VStorm
jgendr is offline
Speedometer Correction flaldrider General V-Strom Discussion 40 06-12-2017 11:57 AM
Speedometer or Speedometer Sending unit? madchap DL650 and DL650A - 2004 to 2011 2 08-06-2015 07:33 AM
The cheap guy's speedometer fix RCinNC DL650A - 2012-2016 34 11-22-2013 11:11 PM
Installed Rostra cruise control now speedometer doesnĚt work Rick54 DL650A - 2012-2016 12 10-04-2012 07:51 PM
Speedometer Accuracy bseaton DL650 and DL650A - 2004 to 2011 14 08-10-2009 03:31 PM
