What top case for two up? - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #41 of 43 Old 06-18-2019, 11:02 AM
Bazooka Joe's Avatar
Originally Posted by RandyinTN View Post
Will a Shad top case fit on a Givi monokey plate?
I did not use the Givi/Kappa kit and I might be off base here, but I think you could use the Givi mount plate to mount a Shad top case. It won't be a direct fit though. You will need to remove the Givi hardware pieces and then drill holes to mount the Shad top case. The Shad case comes with the plastic sub-plate which can easily mount to a flat surface, and also comes with a bag full of various fastening hardware.
The toughest part of mounting the Shad to a flat surface, is determining centerline of the bike, rack, and case. Otherwise, your case will not be all centered and straight and stuff. And if you're carrying a passenger, you also need to determine front/back mounting position too. And be warned- The front/rear mounting location decision can be a very good opportunity for an excellent marital bonding experience.
Webfors likes this.
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is offline
post #42 of 43 Old 06-21-2019, 04:07 PM
basshead's Avatar
I'm running the Shad SH40 with their adapter plate and backrest pad and wife like it very much.
2018 Yellow DL1000
basshead is offline
post #43 of 43 Old 08-16-2019, 12:58 AM
I am using the Shad adapter plate with Givi rack supports, just had to drill 2 holes in the plate. I have the Shad 42 top case.
dajaha is offline
First ride report great to awful and back again Numbercruncher DL650A - 2012-2016 34 08-18-2017 03:13 PM
Complementray alum. top case for Tusk panniers under $200 Slickrock Maintenance, Tech and Products. 2 01-28-2017 08:06 PM
The $100 top case Fly Navy Maintenance, Tech and Products. 15 10-21-2014 09:24 PM
