What top case for two up? - Page 4 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #31 of 41 Old 04-02-2019, 08:44 AM
Anthony_L's Avatar
I think Moose Racing (if you like any of their boxes) have a mounting plate that has up and back mounting positions on the plate.
Anthony_L is offline
post #32 of 41 Old 04-02-2019, 09:11 PM Thread Starter
Bazooka. Thanks for the info! I’m still deciding between givi and Shad for the top and side cases.
Captainmorgan70 is offline
post #33 of 41 Old 04-03-2019, 07:10 PM
Rolex's Avatar
Originally Posted by uscgmac View Post
Can you use the lock cylinder provided by Suzuki that came with the bike with the shad top case. I'm thinking about going with the 39L top box.
Sent from my SM-J700T using Tapatalk
Sorry I can't answer that I have never seen the Suzuki locks ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #34 of 41 Old 04-04-2019, 11:29 AM
uscgmac's Avatar
When I bought the bike it came with three lock cylinders that match the bike ignition key. They look like standard lock cylinders. I would imagine all the v storms come with them but I could be wrong. Did you buy new, if not maybe the previous owner used the locks and then sold the luggage separately. It would be nice if the locks were compatible with other then Suzuki luggage.
Sent from my SM-T350 using Tapatalk
uscgmac is offline
post #35 of 41 Old 04-04-2019, 12:40 PM
tenny80's Avatar
Originally Posted by Captainmorgan70 View Post
Bazooka. Thanks for the info! Iím still deciding between givi and Shad for the top and side cases.
I would rule out Givi if you are doing 2up, there rack system is awful. I had custom plates made up to lower it and move it back but it leaves no leg room at all. My wife and son wouldn't even ride on the V2 with Outback Trekker luggage.
2018 Vstrom 1000
tenny80 is offline
post #36 of 41 Old 04-04-2019, 12:52 PM
MattR302's Avatar
For 2-up, make sure you get a big enough top case that can easily fit 2 helmets, that way you can lock them up if you stop on a trip.
Donít worry about one size looking ďout of proportionĒ too big. The difference between a ~40L case and ~52L case is only an inch or two in each direction. Once you put a topcase on a bike, it already changes the look so significantly, a slightly larger one really isnít going to look so much more out of place, so you might as well go big.
In regards to brands, Iíve only used Givi, but make sure you get the Monokey, not Monolock. Monolock is the lower-quality line designed for scooters, Monokey ones are a little more rugged.
Donít worry about needing a backrest pad on the top case. They tend to push the passenger more forward, and since your passengers jacket likely has a back pad/armor, extra padding isnít necessary.
MattR302 is offline
post #37 of 41 Old 06-17-2019, 10:29 PM
phatguy in Cbus
phatguy's Avatar
My co-pilot likes this back rest solution. It has been mounted on four bikes to date. She say's trade bikes all you want, but insists on keeping the back rest. It originally came from Captain's Lair and was designed for a Honda St-1100. It's been modified several times and is currently on a R12GS. The picture is from previous '14 Vee.
Jim in Cbus
Current ride:
07 R1200GS (Barn Queen)
Gone rides: DL1000A; DL650A; F800ST; R1100RT;
DL1000; Royal Star V4; Concours; Kawa 650/4;
Honda CB350; BSA Thunderbolt 650; YDS 305;
YDS 250
phatguy is offline
post #38 of 41 Old 06-17-2019, 11:02 PM
Webfors's Avatar
Agree on the Givi/Kappa aluminum top rack with the side supports.
I went with the Kappa KGR52 (same as the Givi TRK52)
https://fortnine.ca/en/kappa-kgr52-monokey-top-case
And the Kappa/Giva 3112:
https://fortnine.ca/en/kappa-top-cas...r-rack-kra3112
And the backrest for 2up:
https://fortnine.ca/en/kappa-k635-backrest-for-kgr52
Two wheels for realz!
Webfors is offline
post #39 of 41 Old 06-18-2019, 09:11 AM
Will a Shad top case fit on a Givi monokey plate?
RandyinTN is offline
post #40 of 41 Old 06-18-2019, 09:26 AM
Webfors's Avatar
Monokey is Givi/Kappa specific. I don't believe you'll find a case from another brand that will work with Monokey plates.
Webfors is offline
First ride report great to awful and back again Numbercruncher DL650A - 2012-2016 34 08-18-2017 02:13 PM
Complementray alum. top case for Tusk panniers under $200 Slickrock Maintenance, Tech and Products. 2 01-28-2017 07:06 PM
The $100 top case Fly Navy Maintenance, Tech and Products. 15 10-21-2014 08:24 PM
