first 600 miles oil change question - Page 8 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 62Likes
Closed Thread
post #71 of 78 Old 02-15-2019, 11:24 PM
RCinNC's Avatar
Sometimes, all you can do is follow the wisdom of Lord Humongous.....
Big B, VSrider and STCorndog like this.
RCinNC is online now
post #72 of 78 Old 02-16-2019, 06:38 AM
PerazziMx14's Avatar
Agreed! Besides I'm thinking of starting an internet store that sells sparkplugs to high end clientele. So I won't have time for this thread anymore
PerazziMx14 is online now
post #73 of 78 Old 02-16-2019, 08:12 AM
Null 13's Avatar
Was the location of the op released? 1 Year seems so low for 2019.
________
2014 VStrom 1000 Adv SE, because army bikes are more adv
Null 13 is offline
post #74 of 78 Old 02-17-2019, 01:30 PM
STCorndog's Avatar
Originally Posted by PerazziMx14 View Post
You are the one who posted Ducati charges $45 per spark plug without researching the facts and were proven wrong.
Again like the vehicle buying scenario just because one idiot paid doesn't mean that's the cost.
You also posted you "rich" doctor buddy will probably keep the $180 spark plugs even though you ordered $56 dollars worth of the same spark plugs from the Yamaha dealer. This makes absolutely no sense why you'd order 2 sets of plugs. But its your lie tell it like you want!
^^^^^^^My buddy is an idiot, I am a liar.
Very nice sir, have a great day.
Moderators, feel free to nuke this thread after my esteemed friend gets the last word in.
P.S. - never volunteer to work on a Multi-Strada. It was not an easy job to complete and the valves were out of spec on both exhausts.
Big B, realshelby, Skew and 2 others like this.
STCorndog is online now
post #75 of 78 Old 02-17-2019, 02:40 PM
locoblanco's Avatar
Originally Posted by STCorndog View Post
P.S. - never volunteer to work on a Multi-Strada. It was not an easy job to complete...
I may have been partly responsible for this with my advice on beverages. I failed to mention the local brews tend to be a bit higher in alcohol content.
STCorndog and Hatchi like this.
locoblanco is online now
post #76 of 78 Old 02-17-2019, 08:11 PM
STCorndog's Avatar
That is why I like IPAs, high alcohol content. We stayed out of the beer until we were done though.
If you check valves on a desmo engine, you are in for a treat. There is a cam lobe to open the valves and a cam lobe to close them. Luckily Youtube has a very good tutorial, but I did not want to try shimming them. We did get the plugs and air filter in pretty easy though, about like an older Strom in the amount of plastic that comes off.
Big B likes this.
post #77 of 78 Old 02-18-2019, 09:03 AM
So you are explaining the Demodromic valve actuation that was developed to help combat valve float that can occur at high RPMS where a spring cannot actuate fast enough and the valve doesn't close the whole way. Ducati's way around this was to mechanically open and close the valve ensuring the valve dis not float.
You stated that the "exhaust" valve or closer needed adjusted as all were out of spec. According to Eraldo Feracchi it is extremely rare for the "closers" to be out of adjustment as they really do not have anywhere near the pressure put on them as the openers. But what does he know? Eraldo and his crew only tinkered with these motors.
https://www.google.com/url?sa=t&rct=...fKiRfcPgNCYt-v
post #78 of 78 Old 02-18-2019, 11:14 AM
Thread has runs it's course, the OP has left the building.
D.T., RCinNC, tenny80 and 2 others like this.
Closed Thread
V-Strom Get Together East X - 17-20 May 2012 jwweldon Events 147 05-25-2012 12:34 PM
Bought my first Vee; oil/fluid change questions as a new owner arooni General V-Strom Discussion 7 02-09-2011 07:38 PM
Crash Bars/Skid Plates- Q&A - all you could ask and then some Skinnifatkid General V-Strom Discussion 11 05-29-2010 12:46 PM
Windshields- Q&A-all you could ask and then some Skinnifatkid General V-Strom Discussion 8 02-15-2010 07:51 PM
Question while in the middle of Oil Change... weehawk General V-Strom Discussion 9 06-12-2008 09:01 PM
