Anyone install a Happy Trails skidplate w/ Givi crashbars? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 25 Old 12-28-2018, 02:16 AM Thread Starter
nvr2old's Avatar
I'm not a "Happy" camper at the moment. Two statements in there ad 1. Works with Factory, Givi and HT bars. 2. Compatible w/factory centerstand.
Deal with #2 first. On the right side rear brackets held between a frame member and the bracket that holds the centerstand. The Thickness of the rear bracket moves the distance between the centerstand pivot and the original bracket out .137". Thus creating a gap. If the bolt is tightened at this point 1 of 3 things happen . A sloppy fit or a bent or broken bracket. Solved this one on my own by making a shim washer(Should have been supplied) of .139 thickness.
Now #1 (Not solved yet) The bracket for hooking it to the crashbars is to large to go between the bar and the valve cover. On the right side the gap is about 3/16" and the part is about 3/8". There photo shows it w/HT bars and that has a 1" gap. Did they not even do a test fit w/Givi?
Who out there has dealt with this? Solution?
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is online now
post #2 of 25 Old 12-29-2018, 11:00 AM
Bugzy's Avatar
I have the same setup. Replace the right side bracket for the crashbar mount with a U-Bolt, nobody will notice it. Then it all fits together easily. I didn't notice any issues with the centerstand pivot, but do not remember how I put that together exactly. Was a few years ago.
Bugzy is offline
post #3 of 25 Old 12-29-2018, 01:34 PM Thread Starter
nvr2old's Avatar
Good to hear that it wasn't just me. I called HT yesterday and he(Tim) said that they didn't know of the problem. I sent pictures and hes going to get back with me.
The idea of the U bolt occurred to me also, but wanted to see what HT could come up with. Glad it works so have an alternate route.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
post #4 of 25 Old 12-29-2018, 02:29 PM
RCinNC's Avatar
I like Happy Trails for the robustness of their products, but they do have some fit and finish issues (in my experience). I've ordered two sets of pannier racks from them; on the second set, they sent the wrong size bolts to attach them to the bike. The powdercoating was also a little substandard, and started flaking off in the first year.
RCinNC is online now
post #5 of 25 Old 01-02-2019, 12:50 AM
basshead's Avatar
Following to see what HT will respond as I plan on getting a their skid plate and crash bars this spring.
2018 Yellow DL1000
basshead is offline
post #6 of 25 Old 01-02-2019, 02:07 AM Thread Starter
nvr2old's Avatar
Using their crash bars would have solved the front mount problem, but I like my Givi bars and want to stay with them. I could just use their front mount plate for a partial pattern and make one that works. The brackets are an additional $80 so I feel they need to make it right or compensate me in some way.
I did get a E-mail back from them that the photos were received and they would get back with me.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
post #7 of 25 Old 01-03-2019, 01:33 PM
basshead's Avatar
ok did you mentioned them the problem about the stand too?
2018 Yellow DL1000
basshead is offline
post #8 of 25 Old 01-03-2019, 02:19 PM Thread Starter
nvr2old's Avatar
Apparently they just install it with the gap. It probably works, but I feel that when theres a bushing thats meant to take the pressure of the bolt tightening just using a thread locker and snugging isn't enough.
The guy on the phone(Tim) sent me an E-mail yesterday that he talked to their installer and was told of a secret stash of U-bolts he kept for the problem. Bolts are in the mail. Communication and follow through aren't strong points apparently. These problems need to be addressed at the time of ordering and on their website.
If there was a reason alternative it would have gone back. The others just don't have the strength of the HT.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
post #9 of 25 Old 01-04-2019, 12:10 PM
Bugzy's Avatar
I am very happy with my HT skidplate, it has slid my bike across several logs and I can lift the bike using it, very solid and functional. 4 bolts to get it off to change the oil.
Bugzy is offline
post #10 of 25 Old 01-04-2019, 05:00 PM Thread Starter
nvr2old's Avatar
You're right, its the sturdiest of whats available and thats why I wanted it. Talked to Tim yesterday and he said that when his installer comes in on Monday they are going over both problems. Future kits will be supplied with proper hardware to take care of this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
Need racks for Happy Trails Panniers new2vstrom DL650 and DL650A - 2004 to 2011 6 06-02-2011 12:21 AM
Happy Trails Panniers on a Vstrom Tim G DL1000 from 2002-2012 13 02-07-2009 01:26 PM
Adventure Motostuff skidplate install - '08 DL650 angrypeppers DL650 and DL650A - 2004 to 2011 10 05-08-2008 11:31 PM
