Bleed brakes on '18 model - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 10-27-2018, 08:06 AM Thread Starter
bosnjo's Avatar
Does anyone know if there was special procedure to bleed brakes on new model?
The new model has connection between front and rear brakes (for emergency braking) and ABS module with angle sensor. Those two things are different between '14 and '18 models.
I asked at my dealer and he made inquiry to main Suzuki service but still has no answer. He also does a lot of servicing of BMW bikes and said, for example, on some BWM models you have to bleed brakes with ignition on, on some others with engine running. I have no idea if connection between front and rear brakes are hydraulic or electrical.
Service Manuals of '18 model would be of great help I guess, but I only have '14 model Service Manuals. Maybe someone can shad some light on the subject.
Thanks.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #2 of 6 Old 10-28-2018, 05:41 PM
Bugzy's Avatar
I believe the 14 manual applies to 18, they just insert additional pages if there is anything 18+ related. No pages, no changes I guess.
When I changed fluid on my 14 I did not need to have engine running and fluid flowed right through ABS unit.
Bugzy is offline
post #3 of 6 Old 10-28-2018, 08:03 PM Thread Starter
bosnjo's Avatar
Well, when I changed fluid on my '14 model, I also had no problems. But now, after I used same procedure on '18 model, two weeks later rear brake was full of air and not working anymore. I bled it and it took so much oil to purge all of the air that I couldn't believe it. When I was bleeding it first time, I didn't let any air in but obviously I did something wrong. Now it has no air but I'll see if it stays ok in next few weeks. I have no ideia where the air found its way in as I haven't touched the pads (cylinders) and bled both brakes and clutch with vertical hose on nipples so old oil was filling the hoses and no way air could get in. Also, I made sure no air could come in through the brake fluid reservoirs as I was topping them up correctly while bleeding the brakes and clutch.
2017 DL1000 White
bosnjo is offline
post #4 of 6 Old 11-25-2018, 01:31 PM Thread Starter
bosnjo's Avatar
Just found out banjo on front left caliper is leaking brake fluid. So, trip to the dealer, I guess.
I was just puzzled with my brakes loosing pressure if bike left sitting for more then a week. Few pumps on the lever would bring brakes back to normal but I knew it's not the way it's supposed to be.
I don't know if only short hose needs to be replaced or whole front left caliper.
2017 DL1000 White
bosnjo is offline
post #5 of 6 Old 11-25-2018, 01:36 PM
nvr2old's Avatar
Shouldn't just a new copper sealing washer solve that?
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is online now
post #6 of 6 Old 11-26-2018, 03:06 AM Thread Starter
bosnjo's Avatar
Thanks for that. Looks like it will be easy job.
2017 DL1000 White
bosnjo is offline
Advice please re 650 K5 brakes ( new owner) willywombat DL650 and DL650A - 2004 to 2011 4 07-03-2014 08:04 PM
Braking by Nick Ienatsch OfirMX Riding Proficiency 0 04-26-2013 09:02 PM
Brake Bleed on ABS Model farmerlou V-Strom Service and Maintenance Questions and Discussions 6 08-07-2011 04:45 PM
Changing Seat Tail Covers Hanadarko DL1000 from 2002-2012 9 02-20-2008 12:32 PM
US Model Differences Jim Davis General V-Strom Discussion 16 02-15-2008 06:02 AM
