2018 DL1000 turn signal relay location - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By MetrickMetal
post #1 of 10 Old 10-15-2018, 10:12 AM Thread Starter
MetrickMetal's Avatar
Does anyone know where the turn signal relay is located on a 2018 DL1000?
I looked underneath the seat where the service manual I have says it is located, but it's not there, and the reason I ask is I'm going to be installing one of their Custom LED flasher relays when I install their Blinker Genies.
2018 black DL1000XA with Arrow header, Holeshot slip-on, mag rims w/silver rim tape, Custom Lamm seat, Aprilia Tuono mirrors, V-Stream sport screen, Givi hugger, Cox radiator guard and lots of custom parts and mods
2007 Suzuki Candy Sonoma Red naked Bandit 1250S/AK7.
MetrickMetal is offline
post #2 of 10 Old 10-15-2018, 10:52 AM
Lrobby99's Avatar
No I don't. But I do like your bike farkle list. Black or shiny Holeshot?
Lrobby99 is offline
post #3 of 10 Old 10-16-2018, 08:03 AM Thread Starter
Thanks, and I have the polished Holeshot slip-on.
post #4 of 10 Old 10-16-2018, 08:56 AM
Brockie's Avatar
To get to the turn signal relay you have to remove the battery, lift the fuse box and then unscrew the plastic below the battery. It's held by 3 vertical screws then 2 more horizontal screws on each side, screwed into the subframe. Then, there are still 2 clips accessed from the wheel arch.
That is where it is on the 2017 DL1000, and I guess your bike will be the same.
Brockie is offline
post #5 of 10 Old 10-17-2018, 04:15 PM
bosnjo's Avatar
I've had whole "book" written here about that relay. Let me try to find it.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #6 of 10 Old 10-17-2018, 04:23 PM
bosnjo's Avatar
Here you go, read the post #11 here:
https://www.stromtrooper.com/dl1000a...8-model-2.html
and then you might find some more interesting stuff here:
https://www.stromtrooper.com/dl1000a...-location.html
2017 DL1000 White
bosnjo is offline
post #7 of 10 Old 10-17-2018, 07:24 PM Thread Starter
Thanks bosnjo
I found your thread the other day but haven't had time to post up that I found it.
post #8 of 10 Old 10-20-2018, 02:37 PM Thread Starter
I just order two pairs of Blinker Genies, and next, I'm going to order an electronic flasher relay and (4) 7057 amber LED bulbs.
Does anyone have any recommendations on what brand of LED bulbs to buy that are bright and not overly expensive?
I had already purchased 4 amber turn signal lenses which I'm also going to install back on the turn signals. So has anyone used the stock incandescent bulbs for the running lights without having any issues with them putting out to much heat and melting the housing or lenses, for if it's not an issue I was thinking of first trying lining the turn signal housings with some really shiny silver insulation tape I have and see how bright the incandescent bulbs are.
post #9 of 10 Old 10-20-2018, 09:38 PM
Brockie's Avatar
Every time I look at LED headlight bulbs the selection is new and the newer ones always seem to be improved.
Rather than LED indicator bulbs I bought these. https://www.aliexpress.com/item/Pair...862333482.html
They are 3 wire to hook up to your position lights.
Brockie is offline
post #10 of 10 Old 10-21-2018, 08:35 AM Thread Starter
Thanks, but they're not my style.
I've ordered stuff before from aliexpress, so I ordered 6 of these bulbs, which I found the same brand on eBay and Amazon for a lot more money, and they got good reviews, and I figured since their so cheap I ordered an extra pair to have for spares.
Installing the blinker buddies, electronic flasher relay, LED bulbs and amber lenses will be one of my winter projects.
https://www.aliexpress.com/item/Katu...AbTest=ae803_4
I also ordered the electronic flasher relay from aliexpress which looks just like the one from SuperbrightLEDS which they sell for $8.95 plus shipping.
https://www.aliexpress.com/item/New-...AbTest=ae803_4
Brockie likes this.
Where is the Turnsignal relay location on schematic? mitch96 V-Strom Service and Maintenance Questions and Discussions 2 09-27-2013 04:39 PM
Amber turn signal bulbs. dangerousdana V-Strom Service and Maintenance Questions and Discussions 4 01-10-2013 10:09 AM
