2018 DL1000 XT - dash socket fuse blown - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-29-2018, 12:43 PM Thread Starter
Does anyone know were I will find the fuss for the dash power socket. I was unaware that my air compressor would overload it. Can I up size the fuss (15amp?) with no reproductions. Thx
ChazEd is offline
post #2 of 3 Old 09-29-2018, 01:44 PM
yamak's Avatar
Accessory power
You should find the fuse in the fuse box under seat, 3 amp I believe, adequate for a phone or gps. The wiring will not support 15/amps with out voltage loss, wire heating - possible melting. See the warning in your manual about the 36 Watt limit. Riders wanting to use heavy loads run dedicated heavier wires to a socket for heated vests, compressors etc. 12 volt wire load charts are available online for sizing wire to meet your needs.
yamak is offline
post #3 of 3 Old 09-29-2018, 04:49 PM Thread Starter
Thx yamak.. if required in a pinch on a backroad ride this weekend) can I hard wire compressor to the dealer installed charging pigtail?
ChazEd is offline
Fitting a 12V accessory outlet - best options DCSF Techy World! GPS, Electronics, etc 37 05-13-2019 09:45 PM
Eastern Beaver Fuse box for 2015 DL1000 V-Tom DL1000A - 2014-2016 3 08-04-2015 10:13 PM
Major Electrical Fault DL1000 Sheds DL1000 from 2002-2012 58 05-04-2014 06:48 PM
