Rattling Sound??? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 14 Old 09-13-2018, 12:06 AM Thread Starter
tenny80's Avatar
Rattling Sound???
Anyone else experience a rattling sound? almost sounds like a key chain rattling around. It's not the chain, and I just put new tires on so it's not that. Any other thoughts? it seems to be coming from the rear of the bike on the exhaust side. I'm thinking something must be lose but I cant find it! It only does it 4-5000rpm.
Bike is a 2018 1000, I've also owned a 2014 1000, 2012 650 and 2005 650 and none of them did this, and this bike didn't either until around 5,000 miles.
2018 Vstrom 1000
tenny80 is offline
post #2 of 14 Old 09-13-2018, 05:53 AM
Griff2's Avatar
Centrestand stop rubber missing or the stand hitting something ?
Griff2 is online now
post #3 of 14 Old 09-13-2018, 09:13 AM
VSrider's Avatar
Any chance a little one dropped a rock in your exhaust?
VSrider is offline
post #4 of 14 Old 09-13-2018, 01:19 PM
Highwayman2016's Avatar
Had a rattle on my 650, the center stand pivot bolts were loose.
2014 650 Strom
Highwayman2016 is offline
post #5 of 14 Old 09-13-2018, 01:51 PM
Bugzy's Avatar
Does the rattle get louder when your riding close to a concrete divider? Try oiling the chain and see if it partially goes away. I know you said it's not the chain, but that sound is hard to pinpoint and it might be reverberating off something on the right side making it sound as though that is where it is coming from.
Check for rocks in front sprocket area as well.
Failing that, I guess you need to check every nut and bolt and make sure rear caliper is installed correctly and nothing loose, or just get a louder muffler and go riding.
Bugzy is offline
post #6 of 14 Old 09-13-2018, 02:39 PM
Bogfarth's Avatar
Had a LOUD rattle up front in that same rev range. Culprit? The relays for my EB headlight harness vibrating between tank and cheek panel. Zip tie solved it neatly.
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
post #7 of 14 Old 09-13-2018, 03:08 PM
Lrobby99's Avatar
In acceleration I hear an odd sound. It does resemble the sound like a key chain rattling on something. So, this could be perfectly normal. What we need are more 17+ owners to chime in.
tenny80 likes this.
Lrobby99 is offline
post #8 of 14 Old 09-13-2018, 03:37 PM
blaustrom's Avatar
Do you have crash bars? Sometimes they make strange noises at certain harmonic frequencies.
Skew likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #9 of 14 Old 09-13-2018, 06:06 PM
I had a cracked one on my 650 that made a terrible racket.
2014 650 Strom
post #10 of 14 Old 09-16-2018, 03:35 PM Thread Starter
tenny80's Avatar
no centrestand on the bike
2018 Vstrom 1000
tenny80 is offline
Rattling sound at move Ennsync DL1000 from 2002-2012 9 01-11-2018 04:13 PM
Dl650 k6 knocking sound when warm Gaszton DL650 and DL650A - 2004 to 2011 17 06-04-2015 04:30 PM
Fuel Pump Sound drunifex DL650 and DL650A - 2004 to 2011 12 04-23-2014 10:40 PM
TOCK Sound Jonno DL650 and DL650A - 2004 to 2011 12 03-17-2013 08:21 PM
Chirping/Whistling sound diagnosis? BryanD DL650 and DL650A - 2004 to 2011 3 10-06-2010 07:45 PM
